Use relative path for referenced worksheets - Solved?
- December 8, 2022
- 2 replies
- 2880 views
Edit: Possibly solved? That was quick... See bottom.
How can I use a relative path when including reference worksheets?
The documentation suggests it is possible: "By default the include region displays the absolute path to the referenced worksheet. You can edit the path and make it relative."
I am collaborating with colleagues on a number of worksheets that include references to other worksheets. These are documents that 3 of us access and edit. We are currently using OneDrive, but the issue would remain even if all documents were emailed around. The "Include: path" changes, but all worksheets can exist in a single parent folder, or even a grandparent folder (which should work with a proper 'relative setup')
I have tried various ways like: ../ or ./ or / or //
https://learn.microsoft.com/en-us/dotnet/standard/io/file-path-formats
I have found some ancient* threads discussing and confirming this ability as far back as 2004, but nothing new, or recent that suggests a way it can be done in Prime X.
Screen capture for reference.
Mathcad Prime 8.0
Thank you in advance!
Edit: Solution?
It looks like if you remove everything except the file name it works. This suggests that there is a limitation on files in the same directory.
