Using vhlookup on a dataset for a vector
frederico.cms
Dear,
I have a dataset where the first column represents the index of a vector and column 2,3 and 4 the three possibilities. The first row contains the classification for a specific condition. The dataset has been manipulated to align these indices and classifications.
My vector, for example, have this format::
However, I'm having trouble getting the vertical-horizontal lookup (VHLOOKUP) to search for each element in my vector and correctly return the value at the intersection based on the classification assigned to each vector element. Anything I tried returned 3x1.
I have tried it all from the similar post:
https://community.ptc.com/t5/Mathcad/Use-vlookup-over-a-vector/td-p/482509
Prime 9 attached.
Maybe you are looking for something like this:
Depending on your needs it could be convenient to turn it into a function
BTW, there seems to be no difference between "LOW" and "MEDIUM"
Prime 9 sheet attached
I can't thank you enough, Werner. That was a brilliant solution.
I have to work much harder on programming, as it is compulsory for manipulating and extracting information from datasets.
By the way, the table is for a hazardous zone study IEC 60079-10-1.
Many thanks again.
Fred
