Hi all,
I want to have variables as follows: T/W=0.8 or W/S=100 etc. However Mathcad won't let me define a variable like that, because I think it actually divide or sth. Is there a way around this?
I don't need to know the W or T, I just want to use T/W or W/S ratio in subsequent calculations.
As an example if I want to solve for V=sqrt(2(W/S)/rho*sigma*CL), I would just use the W/S ratio that I would have already defined.
Only in Mathcad 15
And there is one way to do it in Prime 2 and 3
I know one hydrodynamics-man who believes that Reynolds did not come up with this criterion and makes calculations as follows:![]()
A have a template created in Prime 2 and use it in Prime 3 and 4
I just copied this, so I will be using whenever I need to.
Thanks very much!
You welcome!
Prime?
If you need colored operator - use pls the template in attach
How did you get that shade of green?? Its not offered in the palette.
Unfortunately we cannot create/mix our own colors the easy way we are used from most other windows software, including MC15.
It is a Prime template, created in Mathcad 15 and converted into Prime!
See please what I see on my screen ![]()
Thanks, I see. So the color was transfered from Mathcad 15 and cannot be (re)created in Prime 😞
I guess there are some things we should be grateful for, then. ![]()
Seriously, though, I think Prime has managed to include just about every colour I wouldn't wish to use, and few of the ones I would. I have this nasty feeling that, in line with the law of historical repetition, we're about to see a return to the era when everybody thought it was cool to have light yellow text, in an unreadable but trendy font, on a light pastel yellow background, preferably with psychedelic purple and black, flashing overlays.
I've just had a rather frustrating experience modifying a Prime 3 worksheet, and (amongst other things) being unable to set the document, plot and solve-block backgrounds, let alone in the colours I wanted. Developing in M15 and importing to Prime somehow seems like a less than efficient workflow method.
Stuart
You could patch the "Ptc.Controls.Core.resources.dll" to get the colors you want, but its painful and probably not worth the effort.
Werner
Yes, I could. However, unless I have a really, desperate, compelling need that cannot be met any other way, I avoid doing non-standard things in Mathcad (or any other language) because it causes too many portability issues ... and Mathcad/Prime has quite enough of those without encumbering it with more!
Stuart
This is how to make it more efficient:
Now now Richard ![]()
How did I *know* you'd suggest that? Must be my Welsh heritage ... ![]()
Ah, if only it were completely true, but Prime has at least got rid of those devilish SUC restrictions, which simplifies some of my worksheets and let's me make better use of some of my old M11 worksheets. It is such a relief to be able to do things the obvious way again! But just as I'm feeling optimistic about using Prime, it goes and does something silly - or to be more precise, doesn't do something ...
Stuart
I appreciate it!
See please one more sheet with var1/var2 ratio graph
And sorry, Christopher, is my answer correct? ![]()
Yes. I marked one of your answers as correct. Thanks!
