Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
It's an acceleration. You should read it as (m/s)/s, the rate of change of velocity (which is m/s). It is more commonly written as m/s², although (m/s)/s is conceptually more accurate. __________________ � � � � Tom Gutman
