Where's my Tinfoil Hat?
RichardJ
Finally, proof that tinfoil hats actually work:
http://www.bbc.co.uk/news/health-11692799
The "trick" is simply that they have to be plugged in to a power supply. The polarity obviously has to be right too, or you turn into a cretin.
If 1 mA can do what they claim, just think what an amp or two could do! I going to plug my tinfoil hat into a 1kV supply right now! By tomorrow morning I will be a mathematical genius!
http://communities.ptc.com/servlet/JiveServlet/showImage/38-1286-6322/tin+foil+hat+smiley.gif
Where do I sign up????
Little bit disappointed about the following quote though.
"However, he said that the study did not prove that the learning of maths skills was improved, just that the volunteers were better at linking arbitrary numbers and symbols, and he warned that researchers needed to make sure other parts of the brain were unaffected"
Mike
StuartBruff
23-Emerald V
(To:RichardJ)
It all seems a bit too much trouble, all that business about connecting headsets up. I have a chair that comes with it's own metal headcap and will readily supply several kV - got it cheap at an eBay auction of goods from Sing Sing. Sit down, strap in and you're well on your way to collecting the Field's Prize!
or should that be Darwin Award?
