Why root function does not find the second imaginary solution?
Cornel
Why is it not found also this solution by the root function?
(To:Cornel)
I was a bit surprised to see that root would even return non-real results with real guesses.
Here are my 2 Cents, using random non-real guesses.
19 REPLIES 19
StuartBruff
23-Emerald V
(To:Cornel)
y runs from -50.  Indices have to start from ORIGIN.
Stuart
Cornel
(To:StuartBruff)
Ok, but still one solution is missing:
The second imaginary solution:
I don't know why this solution it is not catched/found it...
StuartBruff
23-Emerald V
(To:Cornel)
Try polyroots.  root's algorithm (without a search range) doesn't cover all complex results).
Stuart
Cornel
(To:StuartBruff)
I understand. Also, I can use solve command and received all 3 solutions.
But I want to understand why in the way as I shown above (with x as a range, and with root function), this way does not find the second imaginary solution as I should be the case.
StuartBruff
23-Emerald V
(To:Cornel)
I enjoy conversations where messages cross each other—so much more fun than a strictly linear thread. 😊
You'd have to dig into the code to understand why Ridder's (or Brent's) algorithm returns one complex root and not the other.  It would help if one could specify a complex range.  Perhaps somebody could write a wrapper function around f(x) that allows root to stray further into the complex plane.  Alternatively, somebody could write a new root function.  I've got vague memories of rolling my own Levenberg–Marquardt solver to better understand what it did.
Stuart
Cornel
(To:StuartBruff)
I found a way:
Cornel
(To:Cornel)
But thanks for this hint. In this way we can use Unique function also when range variable is negative.
StuartBruff
23-Emerald V
(To:Cornel)
Yes, Mathcad doesn't care what the minimum value of the range variable you used was, as long as you ensure that all indices are equal to or greater than (current) ORIGIN.
Stuart
StuartBruff
23-Emerald V
(To:Cornel)
I like it.  If it doesn't work first time, hit it with a bigger hammer!  🙂
However, when I changed x to match your new values in my download of your worksheet, Unique gave a different result.
I used one of my versions of the function set (which does the same sort of thing as Unique).  That gave a better result ... stepping x by 10 gives a lot of (default) zeros.  I wrote out UniqueP from Tetsuro's original post, which gave the same result as yours.  I wonder what's going on?
Stuart
Cornel
(To:StuartBruff)
Be aware that in the first post when I uploaded my mathcad prime sheet I had 0 for the second element. I changed to 1, to skip the first 0. Only that I modified (0 -> 1) from the uploaded file.
StuartBruff
23-Emerald V
(To:Cornel)
OK.
The mystery is solved.  The -1s in Unique's result aren't all -1s.  Showing a few more decimal places shows that beating root into submission with a heavy integer hammer gives more than just the three expected roots.
So Unique and my set0 are looking for strict numerical equality, whereas my set2 only looks for approximate equality as determined by the system variable TOL.
Stuart
StuartBruff
23-Emerald V
(To:Cornel)
Just some random thoughts, particularly concerning the skipped elements in A that are set to 0 by default.
There are other methods of dealing with this issue, but I like to use functions to convert between data types, so ...
Stuart
Mathcad Prime 10 file attached.
StuartBruff
23-Emerald V
(To:Cornel)
As to why, ...
Mathcad Help:
The root of a function is the value at which the function equals zero.
polyroots(v)—Returns a vector containing the roots of the polynomial whose coefficients are in v.
By default, polyroots uses the LaGuerre method which is iterative and searches for solutions in the complex plane. If you want to use the Companion Matrix method instead, right-click on the polyroots function and select the method from the menu. The Companion Matrix method converts the equations into an eigenvalue problem. Learn more about choosing a solving algorithm for the polyroots function here.
root(f(var1, var2, ...), var1, [a, b])—Returns the value of var1 to make the function f equal to zero. If a and b are specified, root finds var1 on the interval [a, b]. Otherwise, var1 must be defined with a guess value before root is called. When a guess value is used, root uses the secant or Mueller’s method; in the case where root bracketing is used, root uses Ridder’s or Brent’s method.
Stuart
I have a strange feeling of deja vu, as if this subject has been discussed in the not too distant past.
(To:Cornel)
StuartBruff
23-Emerald V
(To:Werner_E)
Now that's interesting.  When I tried that, Mathcad squawked like a parrot on a sugar high.  "No, take that nasty complexity out right now! Honestly, some people. Pieces of Eight. Who's a pretty CAS. The horror, The horror ...".
The local definition I used above arose from such an attempt. However, with freshly typed expressions this time, the parrot was rather quiet.
Reducing the range over which root searched gave better (for values of "better") results.
I blame any typos, logical errors and programming mistakes on it being Oh Dark O'Clock and sleep deprivation taking its toll.
Stuart
Cornel
(To:Werner_E)
StuartBruff
23-Emerald V
(To:Cornel)
@Cornel wrote:
Some button jabbing sessions weren't converging at all with small nz.  At first, I thought I broken something because I wasn't seeing any results or was only getting one result.  So, I modified my smart monkey program to trap convergence errors and increased nz.
Stuart
I felt deeply unsatisfied looking at that image and realized it needed a good sorting. Unfortunately, Mathcad's standard sort algorithm doesn't sort complex numbers in a satisfactory order - it sorts on the Re element only; the Im order is somewhat arbitrary.
So,  I dug up one of my old Mathcad 15 mergesort worksheets and reworked it to sort on Re then Im.  Csort(A,clist) sorts array A using the column order specified in clist.  zsort(A) sorts the elements of array A in ascending order, retaining A's shape.
Sorting the symbolic solver's roots and the numerical solver's roots allows for an easier comparison of the different sets of solutions.
Stuart
zmrunif = z m r unif = complex matrix random uniform
zmrunif(m,n,a,b) : return matrix of size m rows by n columns with random numbers spanning the range a to b, where a and b are possibly complex.
