Why root function does not find the second imaginary solution?
Why is it not found also this solution by the root function?
Werner_EAnswer
I was a bit surprised to see that root would even return non-real results with real guesses.
Here are my 2 Cents, using random non-real guesses.
23-Emerald V
y runs from -50.  Indices have to start from ORIGIN.
Stuart
Cornel19-TanzaniteAuthor
Ok, but still one solution is missing:
The second imaginary solution:
I don't know why this solution it is not catched/found it...
23-Emerald V
Try polyroots.  root's algorithm (without a search range) doesn't cover all complex results).
Stuart
I understand. Also, I can use solve command and received all 3 solutions.
But I want to understand why in the way as I shown above (with x as a range, and with root function), this way does not find the second imaginary solution as I should be the case.
23-Emerald V
Just some random thoughts, particularly concerning the skipped elements in A that are set to 0 by default.
There are other methods of dealing with this issue, but I like to use functions to convert between data types, so ...
Stuart
Mathcad Prime 10 file attached.
23-Emerald V
As to why, ...
Mathcad Help:
The root of a function is the value at which the function equals zero.
•polyroots(v)—Returns a vector containing the roots of the polynomial whose coefficients are in v.
•By default, polyroots uses the LaGuerre method which is iterative and searches for solutions in the complex plane. If you want to use the Companion Matrix method instead, right-click on the polyroots function and select the method from the menu. The Companion Matrix method converts the equations into an eigenvalue problem. Learn more about choosing a solving algorithm for the polyroots function here.
•root(f(var1, var2, ...), var1, [a, b])—Returns the value of var1 to make the function f equal to zero. If a and b are specified, root finds var1 on the interval [a, b]. Otherwise, var1 must be defined with a guess value before root is called. When a guess value is used, root uses the secant or Mueller’s method; in the case where root bracketing is used, root uses Ridder’s or Brent’s method.
Stuart
I have a strange feeling of deja vu, as if this subject has been discussed in the not too distant past.
Werner_E25-Diamond IAnswer
23-Emerald V
Now that's interesting.  When I tried that, Mathcad squawked like a parrot on a sugar high.  "No, take that nasty complexity out right now! Honestly, some people. Pieces of Eight. Who's a pretty CAS. The horror, The horror ...".
The local definition I used above arose from such an attempt. However, with freshly typed expressions this time, the parrot was rather quiet.
Reducing the range over which root searched gave better (for values of "better") results.
I blame any typos, logical errors and programming mistakes on it being Oh Dark O'Clock and sleep deprivation taking its toll.
Stuart
