arrray index invalid
fahmed-2
I am trying to assign the last row of a vector of values to my result. I want to start assigning from the second column and assign that value in the first column of a new variable but it is telling me that array index is invalid. Please help me to solve it.
Thank you,
Faisal
LucMeekes
(To:fahmed-2)
See if this helps.
Hi Faisal,
You iterate to the last element in the counter "i",  You cannot index to :"i +1" past the last element,
Simply adjust the counter "i".  See enclosed.
Terry
fahmed-2
(To:terryhendicott)
Hello Terry,
Thank you for your reply. Is this a prime 5.0 file, my version is 4.0.
LucMeekes
(To:fahmed-2)
See if this helps.
fahmed-2
(To:LucMeekes)
Thank you
