generate a specific combinatorial sum symbolically
LucMeekes
Collabs,
I need help with generating a specific combinatorial sum for the symbolic processor (Mcad 11).
See attachment.
Thanks for your time
I think the attached shows a simple function that does what you want.
stv
19 REPLIES 19
Haven't really spent much time using symbolic's, but think I have solved for Equation 2.
Mike
Oh, Luc ! ... You are liquefying my brain .
I have recognized 3 quicly enough .
But if it can be completed, then numerical is just enough.
What all that does represent ? Has it got something to
do with the "Chemical pseudoinverse" ?
I think Stuart & Richard would be good in there [Mike too].
Jean
LucMeekes
(To:jeanGiraud)
Jean,
To (partly) satisfy your curiosity:
the expression is part of the denominator of an expression that describes outputs of a specfic n-channel amplifier.
In there each Ai is a more complicated expression by itself.
Mathcad (11) is capable of solving my entire n-channel amplifier symbolically, sometimes up to n=4, after which I can evaluate solutions numerically, for n=4 and higher (haven't tried to find the limit yet).
I want to describe the (full) solution in a way that enables to understand it's structure. So I need a compact description of that specific sum of n summations.
That requires I need to "simplify" and you know how good CAS systems are at simplifying.... although I learned a few new tricks in Mathcad along the way.
Luc Meekes wrote:
Jean,
Thanks Luc, for the explanation.
Though I don't understand the logic in such complicated construct, but applied it quick. That would represent a coding of some sort [just a comment to maintain my brain in gear]. Your last part is the permutation, that works symbolically but can't be extracted . We need a brain storm from collabs in there ! Another way to get the permutations is the lexico construct or from tables [Neil Sloane]. But you have to make sure that all the components are really as they reveal up until your expression [4]. If all those components are true, what's left is the symbolic construct of the permutations, for instance the 6 permutations of [a,b,c] = [a,b,c], [a,c,b], [c,a,b], [c,b,a],[b,a,c], [b,c,a] ... most gorgeous would be an "n permute". The rot(v,n) does it but can't be extraced symbolically for a literal module to apply. I'm sure any reader will be interested as already tuned to the challenge. BTW, the centroid member works for any length but it sems you ignore the last term.
Cheers Luc, Jean
The spell check does not in there , Why ? Don't know.
The spell check also can't understand two words joined without a gap. It just makes a suggestion of the first word, doesn't offer a space as a suggestion - Unlike WORD.
Mike
Luc,
Solved equation 3 see attached. As Jean said one of the more experienced users should be able to show a simpler solution than mine. Hey, still works though.
Cheers
Mike
Luke.
No feedback on the sheets I provided!!
No good?
Mike
Mike,
sorry, I hope I didn't offend you.
I've looked at them to see if I could generalize your particular solutions and saw no way (yet).
Luc,
Not at all.
Gold star to Alan for solving.
Mike
Hello Luc,
Finished but the last permutation, can't get it work symbolic otherwise than local and manual, i.e: can't be programmed. Will post tomorrow. Make sure the pattern is extensible , it's not obvious even with expansion 4.
Jean
Luc,
You will understand everything. You can really make it as you wish but for the last term, if you want it more developed, it will take a big bit more construct even for a permute as simple as [a,b,c]. .. But it would be possible. Was very interesting, I never thought the "Centroid" could be applied. In fact, it could do the all lot by itself whereas it is variable in length. Just a matter of adapting or revising the concept of the project [speaking to myself].
Jean
stv
Alan,
Looks like you have crack it.
Can you explain how the fucntion still works when RED?
"Can you explain how the fucntion still works when RED?"
It's only the numerical solver that would need the a's to be pre-defined. The symbolic solver doesn't give a monkeys!
stv
Of course, cheers Alan.
LucMeekes
(To:AlanStevens)
Thanks Alan,
I suspected that it should be doable by a function, although I thought a recursive function would be needed (if you look at my attempt, you'll see why).
You showed that that isn't necessary.
I've checked your solutions against my stuff, and as far as I've gone the solution is correct.
Now my next task is to embed this function in my symbolic calculation sheet, and see if it works there.
Thanks!
Works fine here.
... not really "combinatorial"
independent of shuffling vector (a)
stv
Alan,
It does, though I missed in the first place. As is, it outputs a single value. I may have muffed the grouping in my first attempt.
Thanks, saved
