"Engineering mathematics" in Mathcad
ValeryOchkov
I'm not a mathematician, but I think it is wrong to Mathcad Prime apply a hint of the new Combined matrix operator "norm of a vector or matrix"
The right is: "Length of the vector or the determinant of a square matrix."
I see a lot discrepancies or apparent errors in the tooltips Mathcad Prime. I showed them to mathematicians. They say it's not just a mistake - it is so named "engineering understanding" of mathematics. Nine out of ten engineers say that the vector length is the number of elements in it. And not just because Mathcad is a function of length (v), returns not the vector length but a number of elements (components?) in vector, but because for the majority of working with Mathcad think that the vector is not a vector in the mathematical interpretation (not scalar), but simply a table column.
What do you think about this?
48 REPLIES 48
Can you explain why you need to convert units using a textbox? Just so we have a better understanding of what you are trying to achieve.
Mike
Hey MIke,
I am making the calculation sheet for pressure drope calculation in high pressure piping for power plant.
I am using textbox for adding my inputs which are in different units.
For this i am using list box/combo box.
When i am difining the Temperature in deegre celsius it shows the error THIS VALUE MUST BE SCALAR.
mayur patel wrote:
Hey MIke,
May be this is a help for you:
http://twt.mpei.ac.ru/ochkov/Mathcad_12/7_14_Unit_Radio.png
Can you please provide a worksheet?
Mike
sorry i am finding some problem to upload it.
Click the 'Use advanced editor' in the top right corner and then you will be allowed to upload documents.
Mike
mayur patel wrote:
Hey MIke,
Alt+0176 C - °C
wayne
(To:ValeryOchkov)
Or use this
Cheers Valery.
Mike
Hey valery can u guide me how to find dynamic viscosity of steam as function pressure and temperature.
RichardJ
(To:ptc-4412520)
There is no way to transfer units typed in a textbox to the output variable. You will have to use the technique Valery shows, or something similar (I would use a listbox rather than radio buttons, but that's just a personal choice).
Can any one guide me how to find dynamic viscosity of Steam at particular temperature and pressure.
Please (thru Mathcad server - http://twt.mpei.ru/MCS/Worksheets/rbtpp/eng/Diag4.xmcd 😞
http://twt.mpei.ac.ru/ochkov/WSPHB/wspDVPT.gif
or thru DLL (see www.wso.ru)
Hey Valery Thanks lot for your reply.
I am using Mathcad version 14.Can u guide me how can i get WaterSteamPro (General) and how can i install it in my system or mathcad.
Please reply as soon as.
MAyur
MAyur
Thanks for the interest to WaterSteamPro.
All instructions are here - www.wsp.ru
You must install the program and get the access thru e-mail orlov@twt.mpei.ac.ru
Hey Valery
How can i Referance my Excle sheet to my Equiation and How my Result direct select the value from the given table.
Suppose i want Viscosity as result i have input of pressure and temperature.
I have table in which different value of viscosity calculated according to the different pressure and tempearture.
How can i get viscosity by giving input of pressure and tempearture?
Why "Hey Valery"?
Must be "Hey All"!
You can use WaterSteamPro in Excel too:
See http://www.wsp.ru/en/samples/wcu/excel/wcu_excel.htm
Hey Valery Thanks But I need editable copy because i have to calculate no. of datas.
U can send editable copyif it possible to you to my Email addres.
It is Mayur.Patel4@essar.com or -
Sorry, Mayur.
But I do not quit understand what do you want to get from me.
