why minerr() cannot work ?
  • October 15, 2014
  • 3788 views
I wanna estimate k0, n, and k in the ODEs, but cannot let Minerr() run in my calculating sheet.
but flexPDE can give a reasonable answer
see the attached picture:
Best answer by Werner_E
Main error was that the interval for odesolve was just up to 1000, but one of the values in tau.exp which you then feed into the resulting functions was 1500.
Minor errors are a typo in the variable name tau.exp (extra period at the and of the name) and the definition of the range t which should be tau.
Werner_E25-Diamond IAnswer
FanCG1-VisitorAuthor
Thank you very much, esp. my "minor" error you pointed out!!!!!!
...And in Given/Odesolve block must be C.A(tau)^n but not C.A(tau)^2.
See in attached file.
