The message you are trying to access is permanently deleted.
Every time I attempt to post a product idea I get ...
correct the highlighted errors and try again.
It would seem that not adding a 'tag' causes this
Hi @346gnu . Do you mean not adding a label? Labels are required to post and will cause that "correct the highlighted errors and try again" message. Let us know if you have any more issues.
Seems like he's hitting the other error message. If he's getting it when forgetting a label, others probably are too. Might want to check the error message processing order on the backend.
I think I saw something similar to that once when I tried to post 2 or 3 different things within a short time span. Could that be the issue?
