Start a Topic button not enabled
eschinzel
6-Contributor
The button "Start a Topic" in Creo Modeling Questions (link below) is disabled. Someone know the reason? I would have a question regarding Creo Parametrics to do.
https://community.ptc.com/t5/Creo-Modeling-Questions/bd-p/CreoModeling
Thanks!
eschinzel
6-Contributor
(To:eschinzel)
I think I found out where I would like, that is: Creo Parametric >> Routed System. In this way the button is enabled.
Thanks all!!!
6 REPLIES 6
TomU
(To:eschinzel)
Those are part of the "old" forum structure.  New Creo Parametric modeling posts should be created here:
https://community.ptc.com/t5/Part-Modeling/bd-p/partsmodeling
Dale_Rosema
(To:eschinzel)
That area has been closed to "new" things since May 2018.
Please try using this area:
https://community.ptc.com/t5/Creo-Parametric-Ideas/idb-p/creoparametric
Dale_Rosema
(To:eschinzel)
I think Tom's link is for discussions and mine is for ideas.
Someone correct me if I am wrong.
eschinzel
6-Contributor
(To:eschinzel)
Thanks all!!!
I am searching for long time to enable 'start a topic' button but its showing disabled only. Can someone help me out?
Leigh
Emeritus
(To:bhavya)
Hi Bhavya,
Based on the image provided, you are trying to start a topic in a Community Category that is read only.
If you are looking to start a topic around Creo - please select the appropriate forum from this CAD category
Please let me know if you encounter any issues or have any further questions!
Leigh
