Can not obtain licence
ptc-4441144
Hi
Im trying to install Creo1.0 student version. The installation guide says that I should obtain a licence from http://free-dl.ptc.com/install/Setup.exe , but the site doesn't link to any file. Does anyone know what I can do ?
- Regards Jógvan
Please see the attachment.
14 REPLIES 14
Hello!
Jógvan Juul Olsen wrote:
...from http://free-dl.ptc.com/install/Setup.exe , but the site doesn't link to any file...
This link contains "PTC Install Manager" .exe package (10,2 Mb).
Hi Valdimir.
That link does give me a exe file that is only 4kb in size, which doesn't do very much.
Does anyone have the file on their computer `? In that case, would it be possible to send it to me ?
- Jógvan
Thanks a lot Vladimir !
No problem.
Sorry to bother you again Valdimir.
But when I try to run Setup.exe, I get this error "Creo 1.0 from PTC has stoppped working".
The problem signature generated by Windows is:
Problem signature:
Problem Event Name: APPCRASH
Application Name: installmgr.exe
Application Version: 29.0.2011.370
Application Timestamp: 4ecd3943
Fault Module Name: installmgr.exe
Fault Module Version: 29.0.2011.370
Fault Module Timestamp: 4ecd3943
Exception Code: c0000005
Exception Offset: 0009dec2
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1080
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Btw, I'm runninng Windows 7 professional 64-bit.
- Jógvan
hello,
Can you please try this link?
http://free-dl.ptc.com/install/setup.exe
I am wondering if something went wrong in the compression via the link in the prior post. Regardless....can you please look at the link I included and give it a try?
If you are still getting a failure, I would ask that you send me the PTC HostID for your machine and I can create the license for you. You can email me at -.
Have you downloaded the media yet for Creo 1.0?
Mark
You are logged in Windows 7 as "Administrator"?
Hi guys
I have the same problem with this setup.exe
I tried to run it on windows 7 64bit as administrator (my main pc)
vista 32bit (laptop) and also on winXP(virtual machine)
every time is the same case
After a long time waiting for setup.exe to start, and (rather quick) "extract" nothing happens .
So I found where the setup.exe extract it self, and I tried to run it manualy, same case
I downloaded the "setup.exe" file from http://free-dl.ptc.com/install/Setup.exe and also from here (attached by VladimirN.)
dorlov
7-Bedrock
(To:Rafal.R)
hello Rafal,
can i connect to your machine to take a look? email me at -
thanks
dima
Hi!
I have the same problem with this setup file.
Problemereignisname:APPCRASH
Anwendungsname:installmgr.exe
Anwendungsversion:29.0.2011.370
Anwendungszeitstempel:4ecd3943
Fehlermodulname:installmgr.exe
Fehlermodulversion:29.0.2011.370
Fehlermodulzeitstempel:4ecd3943
Ausnahmecode:c0000005
Ausnahmeoffset:000a621a
Betriebsystemversion:6.1.7600.2.0.0.256.1
Gebietsschema-ID:3079
Zusatzinformation 1:0a9e
Zusatzinformation 2:0a9e372d3b4ad19135b953a78882e789
Zusatzinformation 3:0a9e
Zusatzinformation 4:0a9e372d3b4ad19135b953a78882e789
Is there a solution available?
Thanks Armin
Hi Armin,
What edition are you trying to install?
Please send me an email at - and I would be glad to help.
mark
hello, I m a french student and I m trying to install wildfire 5.0 school edition.
before launching the software I have to find the file license. I have previously downloaded PTC license server but I can t find the file. and even if I susbcribe to PTC.com I don t manage to obtain my licence by internet, I m connected but the software isn t able to reach PTC.com. Does someone know how can I have it ? is there any other solution ?
thank you very much
Hello Thomas,
Please submit your question using the PTC Academic Support request for more focued support on this issue.
http://www.ptc.com/appserver/wcms/forms/index.jsp?&im_dbkey=142574&icg_dbkey=482
PTC Academic
