Creo 5.0 Educational License Invalid
AaronB
3-Newcomer
I think other people have found this out too. When I try to install Creo 5.0 Educational Edition it gives an error at the license step. Any idea when this will be fixed? I'm going to stick with 4.0 for now...
6 REPLIES 6
AaronB
3-Newcomer
(To:AaronB)
I can't reinstall 4.0 either. Please give us a valid license code or fix whatever it is that caused all student installs to fail.
AaronB2
2-Explorer
(To:AaronB)
Update: Use BK500806ED0790-Y3M9-4RW5 as the license key and all should go well.
Poojita
3-Newcomer
(To:AaronB2)
I've been trying to install Creo 5.0 with code BK500806ED0790-Y3M9-4RW5 . It indicates license identification to be successful but the license source is indicated to be invalid file or format and I am unable to proceed. What do I do now?
please upload your license file, I can check its contents.
Sometimes installer has problems with network cards. Please open Command Prompt window, enter ipconfig /all > ip.txt command and upload ip.txt file. I will check its contents.
Martin Hanák
does this have something to do with operating system version?
I do not think so. Windows 7 and 10 Professional are supported.
Martin Hanák
