I think other people have found this out too. When I try to install Creo 5.0 Educational Edition it gives an error at the license step. Any idea when this will be fixed? I'm going to stick with 4.0 for now...
I can't reinstall 4.0 either. Please give us a valid license code or fix whatever it is that caused all student installs to fail.
Update: Use BK500806ED0790-Y3M9-4RW5 as the license key and all should go well.
please upload your license file, I can check its contents.
Sometimes installer has problems with network cards. Please open Command Prompt window, enter ipconfig /all > ip.txt command and upload ip.txt file. I will check its contents.
does this have something to do with operating system version?
I do not think so. Windows 7 and 10 Professional are supported.
