If I am making a custom widget, how do I add a custom Category (so when you click the Category dropdown, I could have my own category)? It's straight forward in the widget IDE code, but how do I physically create the category in the ThingWorx IDE?
Paul, it looks like the categories are hard-coded and custom categories are not possible at the moment. While you can tag a widget to multiple existing categories, new ones cannot be added. I've added an enhancement/ improvement request for the same. Thanks!
I asked the same question directly to support, and still ( after 2 months) I'm waiting for the answer... Let's see if somewhere here has the answer.
Paul, what version of the platform are you using? I've created a JIRA ticket with the devs regarding this. I'll be able to provide more information once I hear back from them.
Thank you so much!
I'm using 6.0 right now.
