When I try to connect Raspberry Pi and ThingWorx,I have a trouble.So,
please let me know what to do.
On the manual,"2.-How-to-read-Temperature-and-Humidity-from-Am2302-
sensor-using-Thingworx-Edge-java-SKD-for-RPI",
if I enter "mvn package" on my PI,it will create the release jar file.
But,I can't failed to execute goal on project temperature-thing.
Are there some things that I should do other than appearing in the
manual?
For example,change the set point of /.m2/settings.xml,/temperature-thing
/pom.xml and so on.
I hope you will be able to provide the information.
You can install your jar locally and modify the pom.xml file under the comment:
<!-- This section adds the maven repository that contains the Thingworx jar -->
<!-- If you cannot access this repository, download your own copy and use the -->
<!-- bin/install-thingworx-jar.sh script to install it locally -->
Here, the new URL to the mvnrepo should be: http://maker01.cloud.thingworx.com/mvnrepo i believe that the current URL is now http://maker01.ptcmanaged.com/mvnrepo which is the former server that we used. So, you need to set the server address which is: http://maker01.cloud.thingworx.com/mvnrepo
Let me know how it went.
I would like to ask every Academic user(a student or professor that is part of the Thingworx Academic program that has a hosted Thingworx in AWS) to post all their discussions on the Academic Forum (Academic Community)
Adrian
Adrian
Thanks.I'll try it immediately.
Is there a more recent location of the maven repository than http://maker01.cloud.thingworx.com/mvnrepo
The old and the new location are both not available.
Or can someone provide the required .jar file.
I know this Raspberry PI Academic program example is old, but it is still available from the ThingWorx main web site.
Can anybody reply to the above query or let know from where the thingworx-common jar can be manually downloaded,
Downloaded the protocol-adapter-sdk from the below link, which had the 5.4.0 version of thingworx-common.
https://marketplace.thingworx.com/tools/protocol-adapter-sdk
I did a couple of things to get around this issue. Like the original poster, I was unable to connect to either remote maven repo. I had a copy of the ThingWorx 5.4 Java SDK, which contains thingworx-common-5.4.0.b445.jar, so I took Adrian's suggestion and installed it in my local maven repository. Here's the command to do that:
mvn install:install-file -Dfile=lib/thingworx-common-5.4.0.b445.jar -DgroupId=com.thingworx
-DartifactId=thingworx-common -Dversion=5.4.0 -Dpackaging=jar
Some things to note about the command:
The original project used version 5.0.0 of thingworx-common.jar, so I made the following modifications to the pom:
<dependency>
<groupId>com.thingworx</groupId>
<artifactId>thingworx-common</artifactId>
<version>5.4.0</version>
</dependency>
I got lucky, and none of the other dependencies had to be changed. The temperature-thing built and deployed as expected, and I was able to run it in both simulated and "real" mode on two different Raspberry Pis.
