I installed program normal, tried to run it and it was problem with licence. I red some of the conversations here and I uploaded the licence again. The message shows that this licence doesn't support this version. Please help!
if you want to use Creo 4.0, then
K-12 students can use Product code BE410708EDSTUDENTEDK12
University students can use Product code BK410705EDSTUDENTUNICL
Hi Martin,
unfortunately, I have the same problem.
I can not remove the old licence from Creo 2.0 on my computer. The folder is empty: C:\ProgramData\PTC\Licensing, but the licence from 2015 ist present.
The new licence is installed successfully.
And Creo is not working, why? I ask for help. Thank you very much!
open Windows Explorer, enter C:\ProgramData\PTC\Licensing into its address bar and publish picture of Windows Explorer window.
I've already solved the problem. The solution was to delete all files from this path C:\ProgramData\PTC\Licensing. After that, I installed Creo again and the licensing works fine. Thanks for your help anyway!
