Re: Creo student version not runnig after installation
SP_10066017
As per this thread - Same problem
i5 4th generation
8gb ram
Windows 10pro 64
1tb hard disk
Intel, Amd Radeon graphics
👉Creo version is 7.0.2.0 Student version
After complete  installation  finish. When I click on creo parametric  nothing is happen! 😔
Please help me.
NOTE 👉When installation was  completed  creo  parametric shows 👉installed with warnings ⚠️
My problem is solved. and I want to give you a bonus tip.
after many many tries........... When I opened my Settings, I noticed that there were a lot of updates pending on my laptop. Then I downloaded and installed all the pending updates, a miracle happened after all the updates, my creo software started running very smoothly, and I was very happy to see it.
You can give this tip to anyone because this tip is very useful and very accurate.😊
10 REPLIES 10
i5 4th generation
8gb ram
Windows 10pro 64
1tb hard disk
Please help me.
modify Creo startup shortcut to contain -g:win32_gdi parameter
Example:
"E:\PTC\Creo7_020\Creo 7.0.2.0\Parametric\bin\parametric.exe" -g:win32_gdi
Martin Hanák
Now I have installed  Creo 8.0 in same system  it is successfully installed .
But  it running very slowly. When I click on anywhere it freezing/hang (pop-up shows creo student versionis  not responding) at every 5-6 seconds.
(Not responding)
(Not responding)
(Not responding)
.................................. (Not responding )!
(Not responding)
(Not responding)
(Not responding)
open config.pro file in Notepad and add following lines at the end of the file.
enable_3dmodelspace_browser_tab no
enable_partcommunity_tab no
enable_resource_browser_tab no
web_browser_homepage about:blank
NOTE: config.pro file in my installation is located in E:\PTC\Creo8_000\Creo 8.0.0.0\Common Files\text
Martin Hanák
nothing is happned....😔 see in the second image  at the top ( Not Responding)
Spoiler
I am sorry I have not any other advice.
Martin Hanák
what next......?
@SP_10066017 wrote:
what next......?
Example:
Martin Hanák
You can try the below steps and see if that helps you resolve the issue:
  1. Try to run the application as Administrator;
  2. Update Graphic Card drivers;
  3. Reboot OS;
  4. Add windows firewall exception for the following Programs - https://www.veritas.com/support/en_US/article.100027250
    1. nmsd.exe<Creo_loadpoint>\CommonFiles\<Datecode>\platform_type\nms
    2. xtop.exe<Creo_loadpoint>\CommonFiles\<Datecode>\platform_type\obj
    3. pro_comm_msg.exe<Creo_loadpoint>\CommonFiles\<Datecode>\platform_type\obj
    4. parametric.exe<Creo_loadpoint>\Parametric\bin
