creo 7.0 failure to install
AG_10549001
7-Bedrock
hello,
I've been trying to install creo 7.0. I followed all the steps until it came to the licensing option. upon putting in the license and logging in, I sat on the processing screen for 4 hours without progress. I attempted to redownload the files, updated my computer, restarted my computer, and even tried to download without a license beforehand. If there is anyone with any pointers or suggestions that would be greatly appreciated.
If you're seeing this, thank you for your time.
Thanks man! You're a life saver! what I did to fix it is install Creo 7.0 under the k-12 license, and then reconfigure the license under the install page
im not sure if you have the same problem as I had but it sounds like.
Someone gave me the solution which worked for me so maybe same for you ...
The link to the chat is: Solved: Licensing fail Creo 7.0 - PTC Community
Hope I could help you 🙂
