i was trying to download creo element on me Dell laptop still not working and now am trying to download it on my Macbook but it looks like it can allow to download it but it cannot work can someone please help?
Creo is only supported on Windows platforms. While this means that you will not be able to install directly on your machine it may be possible that you can run a dual boot with Windows (example: using bootcamp) or Windows in a virtual session (example: using Parallels) and then run the application.
That said, you should be able to download the DVD onto any computer, it just takes some time. The data is over 4GB so it will take hours to download, typically 2 to 5 hours.
so how is it be done to run dual boot with window
Sorry but having never owned one, I don't know anything about a MAC. I do know that you can find info about Bootcamp at www.apple.com.
Information on Boot Camp can be found by reading this article on apple.com Mac Basics: Using Windows on your Mac via Boot Camp
