problem "error" with the licence
HL_10866117
2-Explorer
Hello, i want to install creo 9 University edition for my studies.
When I entered BK120908EDUNIVERSITYED under sales number order or product code. It didn't go through and displays ERROR in red.
Same with the BK900908EDSTUDENTEDUNI code which some people of my university used.
I alredy had creo and my licence expired so i needed to install it again and i have already done it with the second sales number. But this time, it says "error" to me.
put following words into Google search and study results.
windows how to get physical address of network card
Martin Hanák
hello, i also saw that i could do that
 You can contact academicsupport@ptc.com (via e-mail). You need to send them the Host ID (Mac address of the ethernet) and also the product code used. I hope they will send you valid license file.
Host ID ... this means physical address of network card
  • if Ethernet network card is installed in your computer then use its physical address
  • if the only network card is WiFi network card then you must turn off MAC address randomization to get real physical address"
But i do not know if it is the same for creo 9 because it was the answer for creo 12,
And i do not understand where is my host ID, is it the login name for creo ?
Thank you for you answers
Martin Hanák
