save a copy assembly window issue? creo 2.0
  • March 2, 2013
  • 2583 views
has the issue with "save a copy" assembly window resolved in creo 2.0 M030?
    What specifically was the problem you had with Save As for assemblies?
    finally someone asked? I have posted a video also on the issue? i will upload the video here also... Video Link : 3785
    As you can see in the video the "save copy " window does not come up properly..then when i try to move to move the window to see the other options in does not move....how will i be able to save copy in this way???????????????
    March 5, 2013
    As Tim mentioned above, the minimum monitor resolution for Creo is 1280x1024 and unless someone on the forums has a clever solution I have not thought about, you will not be able to use the Save a Copy functionallity.
    I was able to duplicate your issue by setting my resolution to 1280x800 and as expected, I was not able to use the Save a Copy functionallity for assemblies.
    Adam
