save a copy assembly window issue? creo 2.0
  • March 2, 2013
  • 2583 views
has the issue with "save a copy" assembly window resolved in creo 2.0 M030?
    What specifically was the problem you had with Save As for assemblies?
    finally someone asked? I have posted a video also on the issue? i will upload the video here also... Video Link : 3785
    As you can see in the video the "save copy " window does not come up properly..then when i try to move to move the window to see the other options in does not move....how will i be able to save copy in this way???????????????
    thanx for your reply...
    well then that is a big problem? Pro|Engineer Wildfire 5.0 was independent of this .......no issues there...the window should still be scalable?........i don't think to be able to use save s copy..i need to replace all my monitors?...i think this is some kind of bug....the window is not scalable diagonally also.....
