simple help with mathcad file
jgrady
2-Guest
I am having difficulty with opening the attached file with my version of mathcad could some please open the attached file and print contents as pdf? Thanks
10 REPLIES 10
Fred_Kohlhepp
23-Emerald I
(To:jgrady)
This can open with Mathcad 15.
What version of Mathcad do you have?
unfortunately 7 😞 advocating for new version but don't have funding yet. Could you post a pdf of the file for me?
thanks fred
-MFra-
(To:jgrady)
It is not .pdf, can it serve the same?
(To:jgrady)
Here's the pdf with all collapsed areas opened und some inserted page breaks for better readbility.
I also add the file in Mathcad 11 format - maybe someone with Mathcad 11 can convert it to MC 7 format.
LucMeekes
(To:Werner_E)
Attached.  saved as Mathcad 7.
It gets big, because when saving as, everything that Mathcad 11 'knows/thinks' is not supported by mathcad 7 is (also) saved as a picture.
(To:LucMeekes)
Obviously the collapsed regions are not supported.
Would they save as needed if you open them first?
LucMeekes
(To:Werner_E)
I didn't look inside.
Here's another attempt with all (were there three?) areas opened. File is even bigger.
(To:LucMeekes)
I think you got all areas.
Not sure why the file is larger. It contains some Pics and Excel tables. Maybe they are stored less efficient in older versions?
There is also a compatibity issue jgrady will have to deal with because the sheet takes "advantage" of the different way, MC12 dealt with local assignments (we have a compatibility switch MC11 vs MC12 in newer versions of Mathcad for that reason).
@jgrady
You will have to manually add a return value to a lot of the calculations. One example:
has to be changed to
VladimirN
24-Ruby II
(To:jgrady)
This document was created in Mathcad 12 version. So you can open it with Mathcad 15 30-day trial version: Thank You for Your Interest in PTC Mathcad 15 | PTC
