Google Chrome PDF export link does nothing. Works fine with Mozilla Firefox
LouStein
Version 94.0.4606.71 (Official Build) (64-bit)
and seems to try to generate page
but only blank document is produced
VladimirN
(To:LouStein)
Try changing the default association - on Adobe PDF.
5 REPLIES 5
VladimirN
(To:LouStein)
Works fine for me (Google Chrome 94.0.4606.81, 32 bit) :
LouStein
(To:VladimirN)
Confirm that it does work when Chrome is pushed into 32bit mode by changing compatibility mode to Windows 95 and it chooses to goto Windows 8
Still someone on the support.ptc.com development should investigate why in 64bit mode why anonymous user fails to generate a good PDF output and seems to stall.
I would consider this a bug?
Unless someone wants to add a caveat to the PDF link not to Google Chrome 64bit mode because a blank PDF file will be generated.
VladimirN
(To:LouStein)
Just tested it. On Windows 8.1 x64 and Google Chrome 94.0.4606.81 (64 bit). All works fine. What kind of PDF printers do you have in your OS? Here are mine:
Adobe PDF,
CutePDF Writer (set by default),
Foxit Phantom PDF Printer.
LouStein
(To:VladimirN)
Default is (going by file associations)
Adobe Reader is installed on 32bit (likely inherited from my original system - 2017)
I don't have any other application associated or installed to read PDF
https://ugetfix.com/ask/how-to-fix-microsoft-edge-that-wont-open-pdf-files/
Yeah, I can't test this any more since I push it to 32bit
If you download MS DEV Test VM and you will see that default Windows install doesn't work correctly
https://developer.microsoft.com/en-us/microsoft-edge/tools/vms/
I had a IE11/Win7 VM set up and it worked. I would need to try with Win10 with MS Edge to verify ...I guess this is a cache issue?
VladimirN
(To:LouStein)
