Support site lest me log a case but says my support is inactive. My license says its active. the Update killed my datalogger and I'm not sure of the case will even get reviewed.
I have done that twice. I guess its not worth fixing - my support is active .
Hi @SlidingDownhill.
I recommend reaching out to the Sales team to verify your entitlements. If there is a systems issue, they would be able to begin an investigation into getting it resolved, or work with you on a purchase/renewal if your entitlements have expired.
Regards.
--Sharon
where are you located? I can get you in touch with a Renewal Advisor (or partner) to validate your status. We also have a designated contact form for Renewals questions: https://www.ptc.com/en/customer-success/renewal-advisor-contact
