ENGAGE= KUDO, REPLY, or SOLVE!
Below are the top engaging PTC Community threads for February! See if your community username made this list! Or, read more about a topic that interests you!
February Top Viewed Noteworthy Posts
- Creo: Centre of Gravity (CG) for parts, assemblies and drawings to be shown as icon?
https://community.ptc.com/t5/3D-Part-Assembly-Design/Centre-of-Gravity-CG-for-parts-assemblies-and-drawings-to-be/m-p/318753
Contributors to the thread: @pimm @KenFarley @ghkhkjhkjh @rrich-2 @BrianTaylor @Shahbazk61 @AntoniodeItaVen @Roy_Crerar
- Creo: Simplify a Assembly into a part
https://community.ptc.com/t5/3D-Part-Assembly-Design/Simplify-a-Assembly-into-a-part/m-p/712889
Contributors to the thread: TomU @gnewman @jgp_shanghai @StephenW @dgschaefer @JLG
@Juanneumann72 @TomD.inPDX @RaphMORIN
- Creo: Placement disappeared
https://community.ptc.com/t5/3D-Part-Assembly-Design/Placement-disapperaed/m-p/288455
Contributors to the thread: @trohwedder @MartinHanak @CTool @pace @bbrinser @Brainjack @pace @saravanang @jnorris @Chilan
- Creo: Creating BOM table in Creo Drawing involving sub assemblies components
https://community.ptc.com/t5/3D-Part-Assembly-Design/Creating-BOM-table-in-Creo-Drawing-involving-sub-assemblies/m-p/485887
Contributors to the thread: @MohaSharifi @MartinHanak @StephenW @Deepakjohsh
- Windchill: What is a WT Part, WT Document, WT Object?
https://community.ptc.com/t5/Windchill/What-is-a-WT-Part-WT-Document-WT-Object/m-p/26648
Contributors to the thread: @ptc-6026219 @AL_ANDERSON @MikeLockwood @KD @BuddyHudson
February Top Engaged Noteworthy Posts
- Creo: @kdirth, @pausob, and @Tdaugherty engaged with former Solidworks user @NR_9770144 shared some tips that can help make the learning curve less steep when Showing Motion with cylinders is a challenge.
https://community.ptc.com/t5/3D-Part-Assembly-Design/Showing-motion-previous-solidworks-user/m-p/710795
- ThingWorx: @DmitryTsarev started a discussion around Underscore characters in output from base64EncodeBytes
https://community.ptc.com/t5/ThingWorx-Developers/Underscore-characters-in-output-from-base64EncodeBytes/m-p/713256#M50570
- ThingWorx: The conversation about Custom code to get data using OData API was started by @ptc-41657.
https://community.ptc.com/t5/ThingWorx-Developers/Custom-code-to-get-data-using-OData-API/m-p/710743
- ThingWorx: @SO9699370 received an Accepted Solution for the issue regarding Error while importing google map widget.
https://community.ptc.com/t5/ThingWorx-Developers/Error-while-importing-google-map-widget/m-p/712224#M50474
- ThingWorx: A PTC eSupport knowledge article was used to support the inquiry by @Ecko665 around Advanced Grid not rendering last column on Twx 8.5.3
https://community.ptc.com/t5/ThingWorx-Developers/Advanced-Grid-not-rendering-last-column-on-Twx-8-5-3/m-p/712905#M50543
- Vuforia: @AceRothstein started a discussion about Toggling of Shaders not working
Thank you, @SurajPatil for also contributing to the conversation!
https://community.ptc.com/t5/Vuforia-Studio/Toggling-of-Shaders-not-working/m-p/713237
- Vuforia: @AS16 received an Accepted Solution for the inquiry around Expand & Collapse Sidebar.
https://community.ptc.com/t5/Vuforia-Studio/Expand-amp-Collapse-Sidebar/m-p/710928#M9331
- Vuforia: @pjahn found some help from PTC Technical Support when he replied to this post regarding New Functionality: Versions and History in Vuforia Expert Capture.
https://community.ptc.com/t5/Vuforia-Expert-Capture/New-Functionality-Versions-and-History-in-Vuforia-Expert-Capture/m-p/713104
- Vuforia: @MAF started the discussion about Get scanned ThinkMark ID Value
https://community.ptc.com/t5/Vuforia-Studio/Get-scanned-ThinkMark-ID-Value/m-p/714929#M9459
- Vuforia: The topic of Allow copy/paste of views (or some other method of duplicating a view proved to be a lively discussion with @ClayHelberg @dsgnrClarK and @mwodarz_INNEO!
Thank you for contributing to the thread!
https://community.ptc.com/t5/Vuforia-Studio/Allow-copy-paste-of-views-or-some-other-method-of-duplicating-a/m-p/711104
- Windchill: Great conversation started by @DanielScheidegg around Windchill 12.0.1.0 without WindchillDS Thank you @AndyHermanson, @MikeLockwood, @TomU, @RandyJones, and @AK_9115379, and @BjoernRueegg
https://community.ptc.com/t5/Windchill/Windchill-12-0-1-0-without-WindchillDS/m-p/712640
- Windchill: @yardsail revitalized a 2015 thread started by @BenitoRuiz How do I load a previous version drawing and assembly into the workspace? Original Accepted Solution by TomU and a new helpful reply by @BenLoosli!
Thank you @Milender20 @alex57 for also contributing to the thread!
https://community.ptc.com/t5/Windchill/How-do-I-load-a-previous-version-drawing-and-assembly-into/m-p/58908#M7122
- Windchill: @Henrik_F received a referral to a eSupport help article and an Accepted Solution from mlockwood-2 for his inquiry about STEP file publishing with revision information
https://community.ptc.com/t5/Windchill/STEP-file-publishing-with-revision-information/m-p/713267
- Arbortext: @kleind received Accepted Solution from @BLArts How to cut multiple lines?
https://community.ptc.com/t5/Arbortext/How-to-cut-multiple-lines/m-p/597286
- Arbortext: @ptc-4791061 asked about Arbortext Editor PDF font issue Thank you, @GarethOakes for contributing to the discussion!
https://community.ptc.com/t5/Arbortext/Arbortext-Editor-PDF-font-issue/m-p/715215
- FlexPLM: @schandrasehkar bumped up a 2019 thread Upcoming Webinar: FlexPLM Reporting: How to Use Query Builder to receive help with a FlexPLM Join model
https://community.ptc.com/t5/FlexPLM-Tips/Upcoming-Webinar-FlexPLM-Reporting-How-to-Use-Query-Builder/m-p/619195/thread-id/81
- FlexPLM: This February a top viewed post created in 2017 Create in New Color Development Request so that is it associated with a Specification and therefore can be added to a tech pack was asked by @csmith-9 . Thank you, @pbanerjee for contributing to the thread!
https://community.ptc.com/t5/FlexPLM/Is-there-a-way-to-create-a-New-Color-Development-Request-so-that/m-p/200981/thread-id/289
- Windchill SSE: @rmuthiahkasthur revitalized the thread Upgrade from old version to latest 12.2.1 started by @kjain-2 and received links to PTC knowledge articles that help support the upgrade path. Thank you, @RN_9813253, for contributing to the conversation!
https://community.ptc.com/t5/Windchill-Systems-Software/Upgrade-from-old-version-to-latest-12-2-1/m-p/712183
- Windchill SSE: @ML_7184897 asked a great question related to PTC Integrity 10.5: Download change package content Thank you, @pmaechtlen , for adding to the thread !
https://community.ptc.com/t5/Windchill-Systems-Software/PTC-Integrity-10-5-Download-change-package-content/m-p/712234
- Mathcad: @AG_9821619 revitalized the thread from 2017 How to Read a Binary COMTRADE Data File started by @ppal Thank you, @LucMeekes for providing the Accepted Solution and helping out this month too!
https://community.ptc.com/t5/PTC-Mathcad/How-to-Read-a-Binary-COMTRADE-Data-File/td-p/182897
