Error while importing google map widget
Hi All,
I ma getting a error when I am importing google map widget in Thingworx 9.1. Can you please have a look and let me know why is the issue coming.
Below is the error message -
ERROR [widget] "CustomCSS" widget type is missing required member widgetProperties()
I am also attaching the widget zip file for reference.
Regards
Swaraj Ostwal
suvermaAnswer
Hi @SO_9699370
It appears that it is necessary to activate the billing for maps to work well but they won’t charge you for anything unless you have over 20,000 people viewing your map each month. Here are some links from internet mentioning the same:
Google Maps shows “For development purposes only”
Solving Google Maps ‘For Development Purposes Only’ Error
I was able to import the google widget extension you provided on my Thingworx 9.1 instance. Please check if "ExtensionPackageImportPolicy" tag is present in your platform-settings.json file or not.
Hello @SO_9699370
If you are still facing the issue than please share the log files from thingworx storage folder. And as mentioned by sachin please also check for ExtensionPackageImportPolicy section under platformsettings.json.
Om Dukiya
Hi @odukiya and @SachinSharma
I have checked the platfrom-setting.json it has ExtensionPackageImportPolicy section in which all field are true. I am attaching log as per your request to help me better.
suverma14-AlexandriteAnswer
Hi @SO_9699370
Support
Hi @SO_9699370.
If you feel your issue has been resolved, please mark the appropriate response as the Accepted Solution for the benefit of others with the same problem.
--Sharon
