Advanced Grid not rendering last column on Twx 8.5.3
- 8 replies
- 4434 views
- Translate All
Hello, I have an issue with an advanced grid (V4.2.1) where it does not render my last column. It is fed by a service with output type <Infotable> but no datashape defined. The service executes fine and I can see all the columns in composer.
As well, I have a configuration service output <string>, result fed to the configuration binding of this widget.
Everything was working well with V4.0.1 but it is deprecated and I cannot get it to render properly with the new version.
I am using TWX 8.5.3, attached pic for reference.
Any ideas?
