July Noteworthy Community Posts!
ENGAGE= KUDO, REPLY, or SOLVE
Below are the top engaging PTC Community threads for July! See if your community username made this list! Or, read more about a topic that interests you!
1. Creo: @Sandy1 asked How to make an assembly "static" and be able to reuse it multiple times? Useful information provided by @Tdaugherty and community replies with vivid illustration by @pausob and @BrianMartin (including the Accepted Solution for this post) confirms @kdirth 's statement that "Creo is an endless adventure: Always more to learn!"
2. Creo: @avero helped @Steve99 out with his question about Pro-Program IF statement…” Looking for help with Pro-Program IF statement. I have a part model that has 2 different bolt hole patterns……”
https://community.ptc.com/t5/Assembly-Design/Pro-Program-IF-statement-question/m-p/675440#M20739
3. Creo: @wbottis Creo question about “Modified object cannot be updated” turns out has an
Accepted Solution found in the Windchill Community by @TomU
https://community.ptc.com/t5/Part-Modeling/Modified-object-cannot-be-updated/m-p/679117#M34436
4. Windchill Software Solutions: @amatei asked in our Windchill Software Solutions Forum about “MKS environment variables when the user changes the view but without running a custom command! With an accepted solution from @LLawton .”
5. Arbortext: @LeonidRudometki asked “How to make callouts with the same numbers for the same objects?" Great first reply by @bfriesen Check it out!!
6. Thingworx Developers: Great question by @PravinDriven “Difference: Thingworx Connection Server vs Load Balancer” and PTC answers!
7. ThingWorx Developers: @TanmeyTWX started an informative conversation about “Edge Analytics” !
https://community.ptc.com/t5/ThingWorx-Developers/Edge-Analytics/m-p/651600#M43156
8. Mathcad: @Marco1954 received formula help with “Invers Function.”
https://community.ptc.com/t5/PTC-Mathcad/invers-function/m-p/677719#M190979
9. Mathcad: @ValeryOchkov taught the community about ”Pi and Prime Numbers.”
https://community.ptc.com/t5/PTC-Mathcad/Pi-and-Prime-numbers/m-p/677039#M190887
10. PLM: @Marco_Tosin provided info to @STEVEG to help his “Select-able report for CN types” inquiry.
https://community.ptc.com/t5/Windchill/Select-able-report-for-CN-types/m-p/677153#M62425
11. Windchill: @josepsb started a conversation about “Massive STATE value change in Windchill” and @BrianToussaint shared a story about how he did this with a “bunch of objects.”
https://community.ptc.com/t5/Windchill/Massive-STATE-value-change-in-Windchill/m-p/676453#M62384
12. Windchill: Lively conversation with @MikeLockwood @Dobrisa @JoshuaHouser @ChiselnMallet @BjoernRueegg and @Behnam about "Windchill packages including published files."
https://community.ptc.com/t5/Windchill/Windchill-packages-include-published-files/m-p/579404#M58320
