March 2021 Community Noteworthy Posts
Jaime_Lee
Community Manager
Noteworthy March 2021 Posts
ENGAGE= KUDO, REPLY, or SOLVE!
Below are the top engaging PTC Community threads for March! See if your community username made this list! Or, read more about a topic that interests you!
1. Creo:  @andrehj    revitalized the 2017 thread started by @hnyström   Export only visible parts from an Assembly asking for help with a “stepfile including many surfaces that are hidden in the part and should not be exported.” Thank you, @TomU  for providing the original Accepted Solution and @kdirth and @ocorten-2  for help with this new inquiry.
https://community.ptc.com/t5/3D-Part-Assembly-Design/Export-only-visible-parts-from-an-assembly/m-p/304959#M30779
2. ThingWorx:  @seanccc started asked Will the event/subscription utilize the ThingWorx cluster?
https://community.ptc.com/t5/ThingWorx-Developers/Will-the-event-subscription-utilize-the-ThingWorx-cluster/m-p/716545
3. ThingWorx:  @DmitryTsarev  provided an Accepted Solution for  @JulianaGuerra  post about Giving RunTime Permission to all Entities of a Project
https://community.ptc.com/t5/ThingWorx-Developers/Give-RunTime-Permission-to-all-Entities-of-a-Project/m-p/716049
4. ThingWorx:  @SO_9699370  inquired about Error for deleting value stream created using CreateThing API in postman
https://community.ptc.com/t5/ThingWorx-Developers/Error-for-deleting-value-stream-created-using-CreateThing-API-in/m-p/716844
5. Vuforia:  @ClayHelberg  started a conversation about Allowing copy/paste of views (or some other method of duplicating a vew) Thank you @dsgnrClarK and @mwodarz_INNEO
https://community.ptc.com/t5/Vuforia-Studio/Allow-copy-paste-of-views-or-some-other-method-of-duplicating-a/m-p/711104
6. Vuforia: @Rudu started Reaper widget without ThingWorx connection post.
https://community.ptc.com/t5/Vuforia-Studio/Repeater-widget-without-ThingWorx-connection/m-p/720599
7. Vuforia: @KM received advice and referral to an article in the Studio Help Center support article for his question related to Navigate view after all steps finished playing
https://community.ptc.com/t5/Vuforia-Studio/Navigate-view-after-all-steps-finished-playing/m-p/716508
8. Vuforia:  @NA_nur  started a great conversation about Vuforia Model Target that also highlighted some differences between Vuforia Studio and Vuforia Engine. This is a thread to watch!
https://community.ptc.com/t5/Vuforia-Studio/Vuforia-Model-Target/m-p/717849
9. Vuforia:  @Aouellets  sparked a conversation related to Voice Selection on HoloLens 2
https://community.ptc.com/t5/Vuforia-Studio/Voice-Selection-on-HoloLens-2/m-p/715401
10. Windchill:  @DanielScheidegg  provided links to new support articles that helped with a discussion that carried over from a discussion about Windchill 12.0.1.0 without WindchillDS. There is even information about an upcoming webcast by PTC Product Management with the PTC/USER Technical Committee!
https://community.ptc.com/t5/Windchill/Windchill-12-0-1-0-without-WindchillDS/td-p/712640
Related PTC Authored Community post here
11. Windchill:  @munruh  started a conversation about Workflow set state
"I have a workflow that is used on almost all of our parts. One of the functions of this workflow is to set the states of the promoted items. It works correctly a majority of the time. Sometimes though, it doesn't.
Thank you,"
https://community.ptc.com/t5/Windchill/Workflow-set-state/m-p/719380
12. Windchill: @gkarthikyn  (on Windchill 2.0) started a discussion around Auto Generation of PDF from Windchill Drawing file after promotion request.
https://community.ptc.com/t5/Windchill/Auto-Generation-of-PDF-from-Windchill-Drawing-file-after/m-p/719532
13. Arbortext:  @MB_8500855  asked about Searching for a string in an ACL file while using using Arbortext Editor 5.3 to help  @GarethOakes  shared a help article.
https://community.ptc.com/t5/Arbortext/Is-there-a-way-to-search-for-a-string-in-an-ACL-file/m-p/715886
14. Arbortext:  @bfriesen started a conversation about Isodraw 2d to 3d Issues with JT files
https://community.ptc.com/t5/Arbortext/Isodraw-2d-to-3d-Issues-with-JT-files/m-p/717469
15. Arbortext:  @xhuang   received an Accepted Solution from  @JeffStevenson  for his error (-103) : Cannot checkout an uncounted license within a Windows Terminal Services guest session.
https://community.ptc.com/t5/Arbortext/error-103-Cannot-checkout-an-uncounted-license-within-a-Windows/m-p/185017#M13063
16. FlexPLM: Thank you   @Lynora_Chew for answering  @schandrasehkar  question posted in Upcoming Webinar: FlexPLM Reporting: How to Use Query Builder webinar post.
https://community.ptc.com/t5/FlexPLM-Tips/Upcoming-Webinar-FlexPLM-Reporting-How-to-Use-Query-Builder/m-p/619195
17. Windchill SSE:  @AndreyVi  asked about Java API: Traffic, Performance and Memory issues while getting item history.
https://community.ptc.com/t5/Windchill-Systems-Software/Java-API-Traffic-Performance-and-Memory-issues-while-getting/m-p/717588
18. Windchill SSE:  @AndreyVi  is looking for answers to how can HTTP compression be enabled for requested issued through the Java API client library? See more details at PTC Integrity Java API: How to enable HTTP compression?
https://community.ptc.com/t5/Windchill-Systems-Software/PTC-Integrity-Java-API-How-to-enable-HTTP-compression/m-p/720188
19. Windchill SSE: A 2016  thread started by @Software   (Ginny) received a lot of views in March! There is also a referral to a help article Is there a way to revert to a previous version of a member in Config Mgmnt.
https://community.ptc.com/t5/Windchill-Systems-Software/Is-there-a-way-to-revert-to-a-previous-version-of-a-member-in/m-p/419776
0 REPLIES 0
