Noteworthy April 2021 Posts
ENGAGE= KUDO, REPLY, or SOLVE!
Below are the top engaging PTC Community threads for May! See if your community username made this list! Or, read more about a topic that interests you!
1. Creo: @VeqTor revitalized the thread Is it possible to redefine default coordinate system and change orientation in Creo Parametric started by @dg-2
Thank you @sully7 @dschenken @Bogdan @pollyhillsus @Iglamit @BenLoosli @TomU @doneill @Kevin
@kdirth for contributing to the thread!
2. Creo: @SM_9791973 received an Accepted Solution from @RPN for the thread How to Export all the Dimensions of the 3D CAD model or CAD assembly in to the excel
Thank you @JB_87049 , TomU , and @SM_9791973 for contributing to the conversation!
3. Creo: The 2016 Mapkey Writing/Edits Tips topic started by @lhoogeveen was revitalized by @BG_9869104
Thank you @psobejko @Trebla @dgschaefer @drutledge @LawrenceS @tleati @staitinger @tbladt @ggalli
https://community.ptc.com/t5/System-Administration/Mapkey-Writing-Editing-Tips/m-p/443729
4. ThingWorx: @Sruthi started the topic Fixed Decimals asking for help with rounding some of the property values to 2 digits after decimal. @nmilleson provided the Accepted Solution.
https://community.ptc.com/t5/ThingWorx-Developers/fixed-decimals/m-p/727636
5. ThingWorx: @AC_9552412 asked about Geometry and Drawing Libraries from Google Maps
https://community.ptc.com/t5/ThingWorx-Developers/Libraries-Google-Maps/m-p/729214
6. ThingWorx: @svisveswaraiya received great feedback and ideas on how to establish
connection between PTC Windchill and ThingWorx platform? Thank you, @HemalathaMsk for participating in the thread.
https://community.ptc.com/t5/ThingWorx-Developers/PTC-Windchill-communication-with-TW/m-p/729680
7. ThingWorx: @sarjasalc received assistance for his post Thingworx 9.1 auto-refresh function doesn´t work for contained mashups
@uyngvesson Thank you for joining the conversation!
8. ThingWorx: @LR_9796586 asked How to set a seed for ThingWorx analytics models
9. Vuforia: @Stefano received an Accepted Solution from @dsgnrClarK for his inquiry around How to manage multiple languages in an experience
10. Vuforia: @Stefano asked How to include a .json file from Vuforia Studio resources
11. Vuforia: @JG_9931924 received an Accepted Solution from @whity for Vuforia Trial Publishing Error
https://community.ptc.com/t5/Vuforia-Studio/Vuforia-Trial-Publishing-Error/m-p/729737
12. Vuforia: @Adrian_G. asked How to Change Model when 3D button is clicked
https://community.ptc.com/t5/Vuforia-Studio/How-to-change-model-when-3D-button-is-clicked/m-p/728547
13. Vuforia: @dsgnrClarK asked How to get the camera picture with HoloLens?
14. Windchill: @khimani_mohiki asked WTDocument primary content delete on Revise? The problem we have at the moment is the file itself has the version in the file name i.e. 123456_v1.s19 but when the Document is revised it carries the primary content forward, so we end up a document revision and primary content revision not matching. Thank you, @mmeadows-3 and @d_graham for contributing to the thread!
Windchill: @Henrik_F received an Accepted Solution from @Ajit_Kulkarni for the Publishing drawings to pdf stopped working
Thank you, @sconroy and @berny2U for adding to the conversation!
https://community.ptc.com/t5/Windchill/Publishing-drawings-to-pdf-stopped-working/m-p/729440#M64041
15. Arbortext: @Tusken_Raider started a discussion about Using HTTPS/SSL to connect to Arbortext Publishing Engine
Thank you @DmitryTsarev @rl @bfriesen for participating!
@GarethOakes contributed!
17. Arbortext: @RZ_9374407 found a post from 1999! Maintenance Renewal for ADEPT 7.0.1 and received information from PTC about renewals!
18. Windchill SSE: @wcatunda-2 inquired about Message: system clipboard data unavailable
19. Windchill SSE: @ptc-4816166 asked How to add multi-line "Work Description" using CLI?
20. Windchill SSE: In May, @kthierer bumped up the si co without a sandbox created before is possible? Question originally started by @MW_8240570
21. Windchill SSE: @ryan_yamamoto asked about Import excel file using Integrity 11.2
22. Mathcad: @ValeryOchkov started the Parabola and Catenary with all its formulas, graphs, and engagement. Great discussion!
https://community.ptc.com/t5/PTC-Mathcad/Parabola-and-catenary/m-p/729191
23. Mathcad: @saadhere started a great discussion around Mathcad Prime 5.0.0: Subscripts in Text Blocks
https://community.ptc.com/t5/PTC-Mathcad/Mathcad-Prime-5-0-0-Subscripts-in-Text-Blocks/m-p/618799
24. Mathcad: Great conversation related to Mathcad vs Python started by @ValeryOchkov
https://community.ptc.com/t5/PTC-Mathcad/Mathcad-vs-Python/m-p/729338
25. Mathcad: Last month @Babard38 revitalized a 2010 post with a “book review” Node List Tolerance Analysis: Enhancing SPICE Capabilities with Mathcad
26. Mathcad: Great conversation related to Mathcad vs Python started by @ValeryOchkov
