How to add multi-line "Work Description" using CLI?
I try to add multi-line "work description" using command line interface?
Similar to the follwong:
im editissue --field="Work Description"="Hello\nThank"?
It seems to me that \n does not create and line feed.
Also can we add file from content in a file?
Thank you
    This also works:
    im editissue --field='Comments=Adding new lines^
    Line1^
    Line2' 123456
    Note: Double quote (") is replaced with single quote (')
    Balu
    You have to escape with ^.
    Replace \n by ^\n.
    HTH
    Thank you for the reply.
    But it does not work very well.
    When I run this command:
    im editissue --field="Work Description"="Line1^\n Line2" 6210729
    On Integrity web client, it still shows like this:
    [izhang, 31-Oct-2012 9:50:36 AM EDT]
    Line1\n Line2
    Any more suggestion? Thanks in advance.
    This is just off the top of my head and hasn't been tested, but have you tried " \r\n "?
    If "Work Description" is a rich longtext field, you can use the "im editissue --richContentField=field=value" command. As Jeremy pointed out with <br>, rich content fields are HTML format.
    Thank you for all the reply.
    "Work Description" is not a rich text filed. Therefore, <br/> does not work.
    I talked to PTC Integrity tech support yesterday and this morning. Currently they do not support this. They will create an RFC for this feature.
    I have to use Java API for this.
    Thanks.
    This also works:
    Line1^
    Line2' 123456
    Balu
