May 2021 Most Noteworthy Posts!
Jaime_Lee
Community Manager
Noteworthy April 2021 Posts
ENGAGE= KUDO, REPLY, or SOLVE!
Below are the top engaging PTC Community threads for May! See if your community username made this list! Or, read more about a topic that interests you!
1.  Creo:  @VeqTor  revitalized the thread  Is it possible to redefine default coordinate system and change orientation in Creo Parametric started by @dg-2
Thank you  @sully7 @dschenken @Bogdan @pollyhillsus @Iglamit @BenLoosli @TomU @doneill @Kevin
@kdirth   for contributing to the thread!
https://community.ptc.com/t5/3D-Part-Assembly-Design/Is-it-possible-to-redefine-default-coordinate-system-and-change/m-p/728652
2.  Creo:  @SM_9791973 received an Accepted Solution from @RPN  for the thread How to Export all the Dimensions of the 3D CAD model or CAD assembly in to the excel
Thank you @JB_87049 , TomU , and @SM_9791973 for contributing to the conversation!
https://community.ptc.com/t5/Customization/How-to-Export-all-the-Dimensions-of-the-3D-CAD-model-or-CAD/m-p/729272#M10297
 3.  Creo:  The 2016 Mapkey Writing/Edits Tips topic started  by @lhoogeveen  was revitalized by  @BG_9869104
Thank you @psobejko @Trebla @dgschaefer @drutledge @LawrenceS @tleati @staitinger @tbladt @ggalli
@Alfred16
https://community.ptc.com/t5/System-Administration/Mapkey-Writing-Editing-Tips/m-p/443729
4.  ThingWorx:  @Sruthi  started the topic Fixed Decimals asking for help with rounding some of the property values to 2 digits after decimal.  @nmilleson  provided the Accepted Solution.
https://community.ptc.com/t5/ThingWorx-Developers/fixed-decimals/m-p/727636
5.  ThingWorx:   @AC_9552412  asked about Geometry and Drawing Libraries from Google Maps
https://community.ptc.com/t5/ThingWorx-Developers/Libraries-Google-Maps/m-p/729214
6.  ThingWorx:   @svisveswaraiya  received great feedback and ideas on how to establish
 connection between PTC Windchill and ThingWorx platform?  Thank you, @HemalathaMsk for participating in the thread.
https://community.ptc.com/t5/ThingWorx-Developers/PTC-Windchill-communication-with-TW/m-p/729680
7.  ThingWorx:  @sarjasalc  received assistance for his post Thingworx 9.1 auto-refresh function doesn´t work for contained mashups
 @uyngvesson  Thank you for joining the conversation!
https://community.ptc.com/t5/ThingWorx-Developers/Thingworx-9-1-auto-refresh-function-doesn-t-work-for-contained/m-p/724990
8.  ThingWorx:   @LR_9796586  asked How to set a seed for ThingWorx analytics models
https://community.ptc.com/t5/ThingWorx-Developers/How-to-set-a-seed-for-ThingWorx-analytics-models/m-p/728071
9.  Vuforia:  @Stefano  received an Accepted Solution from @dsgnrClarK  for his inquiry around How to manage multiple languages in an experience
https://community.ptc.com/t5/Vuforia-Studio/How-to-manage-multiple-languages-in-an-experience/m-p/728820#M9792
10.  Vuforia:  @Stefano  asked How to include a .json file from Vuforia Studio resources
https://community.ptc.com/t5/Vuforia-Studio/How-to-include-a-json-file-from-Vuforia-Studio-resources/m-p/729025
11.  Vuforia:   @JG_9931924   received an Accepted Solution from  @whity  for Vuforia Trial Publishing Error
https://community.ptc.com/t5/Vuforia-Studio/Vuforia-Trial-Publishing-Error/m-p/729737
 12.  Vuforia:   @Adrian_G.  asked How to Change Model when 3D button is clicked
https://community.ptc.com/t5/Vuforia-Studio/How-to-change-model-when-3D-button-is-clicked/m-p/728547
13.  Vuforia:  @dsgnrClarK  asked How to get the camera picture with HoloLens?
https://community.ptc.com/t5/Removed-Content/Re-How-to-get-the-camera-picture-with-HoloLens/m-p/725011/thread-id/1600
14.  Windchill:  @khimani_mohiki  asked  WTDocument primary content delete on Revise?  The problem we have at the moment is the file itself has the version in the file name i.e. 123456_v1.s19 but when the Document is revised it carries the primary content forward, so we end up a document revision and primary content revision not matching. Thank you,  @mmeadows-3   and  @d_graham  for contributing to the thread!
https://community.ptc.com/t5/Windchill/WTDocument-primary-content-delete-on-Revise/m-p/728699
Windchill:   @Henrik_F  received an Accepted Solution from @Ajit_Kulkarni   for the Publishing drawings to pdf stopped working
Thank you,  @sconroy and @berny2U for adding to the conversation!
https://community.ptc.com/t5/Windchill/Publishing-drawings-to-pdf-stopped-working/m-p/729440#M64041
15.  Arbortext:  @Tusken_Raider started a discussion about Using HTTPS/SSL to connect to Arbortext Publishing Engine
Thank you @DmitryTsarev   @rl  @bfriesen for participating!
https://community.ptc.com/t5/Arbortext/Using-HTTPS-SSL-to-connect-to-Arbortext-Publishing-Engine/m-p/708018
16.  Arbortext: @Darquise  asked a question about Generating index on large document
@GarethOakes   contributed!
https://community.ptc.com/t5/Arbortext/generating-index-on-large-document/m-p/729104
17.  Arbortext:  @RZ_9374407 found a post from 1999! Maintenance Renewal for ADEPT 7.0.1 and received information from PTC about renewals!
https://community.ptc.com/t5/Arbortext/Maintenance-Renewal-for-ADEPT-7-0-1/m-p/729548
18.  Windchill SSE:   @wcatunda-2  inquired about Message: system clipboard data unavailable
https://community.ptc.com/t5/Windchill-Systems-Software/Message-system-clipboard-data-unavailable/m-p/105321
19.  Windchill SSE:  @ptc-4816166  asked How to add multi-line "Work Description" using CLI?
https://community.ptc.com/t5/Windchill-Systems-Software/How-to-add-multi-line-quot-Work-Description-quot-using-CLI/m-p/129095#M1502
20.  Windchill SSE: In May, @kthierer bumped up the si co without a sandbox created before is possible? Question originally started by  @MW_8240570
https://community.ptc.com/t5/Windchill-Systems-Software/si-co-without-a-sandbox-created-before-is-possible/m-p/710472
21.  Windchill SSE:  @ryan_yamamoto  asked about Import excel file using Integrity 11.2
https://community.ptc.com/t5/Windchill-Systems-Software/Import-excel-file-using-Integrity-11-2/m-p/676339
22.  Mathcad:  @ValeryOchkov  started the Parabola and Catenary with all its formulas, graphs, and engagement. Great discussion!
https://community.ptc.com/t5/PTC-Mathcad/Parabola-and-catenary/m-p/729191
23.  Mathcad: @saadhere  started a great discussion around Mathcad Prime 5.0.0: Subscripts in Text Blocks
https://community.ptc.com/t5/PTC-Mathcad/Mathcad-Prime-5-0-0-Subscripts-in-Text-Blocks/m-p/618799
24.  Mathcad: Great conversation related to Mathcad vs Python started by @ValeryOchkov
https://community.ptc.com/t5/PTC-Mathcad/Mathcad-vs-Python/m-p/729338
25.  Mathcad: Last month  @Babard38 revitalized a 2010 post with a “book review” Node List Tolerance Analysis: Enhancing SPICE Capabilities with Mathcad
https://community.ptc.com/t5/PTC-Mathcad/Node-List-Tolerance-Analysis-Enhancing-SPICE-Capabilities-with/m-p/445439
26.  Mathcad: Great conversation related to Mathcad vs Python started by  @ValeryOchkov
0 REPLIES 0
