See the Top Community Engagers and the Top Noteworthy posts for the month of December.
Top December 2022 Community Engagers:
@Werner_E @HelesicPetr @avillanueva @VladimirN @MartinHanak @ttokoro @LucMeekes @Shashi_Preetham @TomU @KenFarley @EdvinTailwind @Dale_Rosema @jensc @ValeryOchkov @StephenW @BenLoosli @OnurNalbantoglu @Eike_Hauptmann @Dayna_M @AlfredFlaßhaar
MOST NOTEWORTHY POSTS
Below are some of the top engaging or most viewed PTC Community topic threads for December 2022! See if your community username made this list! Or, read more about a topic that interests you!
1. Creo: @J10119210 asked how to pain the part at the asembly or sub-assembly level so that its color is also automatically. Great contributions by @StephenW @kdirth @EdvinTailwind @MartinHanak @Patriot_1776 @KenFarley
https://community.ptc.com/t5/Analysis/Ansys-Simulate-for-Study-of-bolt-pretension/m-p/840131#M10997
2. Creo: @MH_10366957 received an accepted solution from @ysinitsyn for topic Toolkit Scripts Receiving failed to start error @MartinHanak @FV and @MH_10366957 thank you for participating in the conversation!
3. Creo: An interesting conversation with @XDN @StephenW and @KenFarley around Gear teeth and spline hub shaft
https://community.ptc.com/t5/3D-Part-Assembly-Design/gear-teeth-and-spline-hub-shaft/m-p/841577
4. Creo: "h" has a "Master Project" and needed help with Modal Analysis of press fit shaft hub assembly and received an accepted solution from @skunks
https://community.ptc.com/t5/Analysis/Modal-Analysis-of-press-fit-shaft-hub-assembly/m-p/841747
5. Creo: A question about Tracking down a circular reference was posted by @AE_9609989 and an Accepted Solution was provided by @tbraxton ! Thank you for contributing to the conversation. @drieffel @pausob @StephenW
https://community.ptc.com/t5/3D-Part-Assembly-Design/tracking-down-a-circular-reference/m-p/709120
6. ThingWorx: @nmutter gave an Accepted Solution to @twxadmin for the topic How to solve below two errors in thingworx? Also if someone can explain root cause of it. @VladimirN and @slangley thank you for your contributions!
7. ThingWorx: The topic Filter queries was posted by @jensc and an accepted solution provided by @TravisPickett Thank you @PravinDriven for contributing to the thread!
8. ThingWorx: . @VladimirN provided a speedy response and Accepted Solution to the inquiry by @AS_1307 about Developer Portal Guides https://community.ptc.com/t5/ThingWorx-Developers/Developer-Portal-Guides/m-p/842075
9. ThingWorx: @BS_10420068 needed help with ThingWorx flow 9.3.4 install error @PaiChung @slangley @TravisPickett
10. ThingWorx: @TanmeyTWX posted the topic Terminate/End SSO user session Logout and received an Accepted Solution from @nmutter @PaiChungthank you for participating in the conversation!
11. Vuforia: @AndreaT shared a post about Reporting on Studio 9.8 AmandaZupfer and @VladimirN
https://community.ptc.com/t5/Vuforia-Studio/reporting-on-Studio-9-8/m-p/843087
12. Vuforia: @Martini3119 posted a topic about Vuforia Studio-Dark Mode/reduce eyestrain @sdidier
https://community.ptc.com/t5/Vuforia-Studio/Vuforia-Studio-Dark-Mode-reduce-eyestrain/m-p/807263
13. Windchill: @Dobi posted the topic CAD worker fails to start and received an Accepted Solution by @avillanueva Thank you for participating @Ajit_Kulkarni @VishwasAnantwar and @rhart
14. Windchill: @Sha11 asked if it is possible to attach a PDF document to a WTPart and received an Accepted Solution from @avillanueva Thank you, @HelesicPetr for participating in the conversation.
15. Windhill: @ScottGivens asked about Deleting older versions of Creo files in Windchiill 11.1 PDMLink (M020, CPS 13) with an Acccepted Solution by @BenLoosliThank you, @Ajit_Kulkarni and @MikeLockwood for participating!
16. Windchill: @Sha11 asked about Calculating an attribute onchage of another attribute and @BjoernRueegg provided an Accepted Solution! @joe_morton and @rhart thank you for participating in the conversation.
17. Windchill: @AI_10204028 had an Installation problem-Windchill 11.2 inquiry @SWeiler_9940261 delivered an Accepted Solution. Thank you @BenLoosli and @avillanueva for participating!
https://community.ptc.com/t5/Windchill/Installation-problem-Windchill-11-2/m-p/843062
18. Mathcad: @AlfredFlaßhaar posted the topic Van Roomen's problem and @LucMeekes provided the Accepted Solution!
https://community.ptc.com/t5/Mathcad/Van-Roomen-s-problem/m-p/843280
20. Windchill SSE:@SA_10491108 asked about Import .SAV file into PTC Integrity Moddeler v8.5a
@MangeshDevraj and provided an Accepted Solution.
21. Arbortext: @dgopois asked about Using ACL, How to replace the string "and" by the character ampersand (&) and @RickSchoenprovided the Accepted Solution.
22. Arbortext: @RickSchoen posted the topic Some Unicode Characters Don't Display in PDF Thank you @GarethOakes for your input!
https://community.ptc.com/t5/Arbortext/Some-Unicode-Characters-Don-t-Display-in-PDF/m-p/844257
