Creo Part file-Password Protected- Open challenge to all
Highlighted
Regular Member
Hello All,
Please find below the attached file "frame.prt". This creo part has an parameter named password .
you can see the features of part only by providing the right password followed by model regeneration.
Good Luck.....
Regards
Anandkumar P
Tags (1)
8 REPLIES 8
Highlighted
Re: Creo Part file-Password Protected- Open challenge to all
Piece of cake.  No password required.
It's worth repeating again, if you can physically open it, you can do anything to it.  There is no way to protect a Creo model once it's been opened.
Highlighted
I will create something special ...that is bit hard to find..
Regards
Anand
Highlighted
It will only work if you can stop us from editing the PRO/Program.
I just simply opened your part, edited the PRO/Program, removed the IF statement with the PASSWORD and regenerated the part.
It took me less than 3 seconds 🙂
Highlighted
Try this case....
Creo Model Lock- Features Hidden
Highlighted
I found it. its quite interesting to find.
Find below attachment
Mani..//
Highlighted
Can you please guide me to unlock it. I tried to open it within 2 months but failed.
Highlighted
Open the part, edit the PRO/Program and remove the IF statement with the password, then regenerate.
Highlighted
Thank you very much! This is the best thing about Creo software that I have ever learned.
