The message you are trying to access is permanently deleted.
Hello every one When starting autoGEM or Analysis and Design Studies,
Creo crashes/forces close. I a...
958
Views
by
PS_10622437
on
Sep 05, 2023
05:24 AM
Latest post on
Sep 11, 2023
06:06 AM
by
ArnaudVandeVeer
1 Reply
585
Views
| I am using Creo Parametric Release 9.0 and Datecode9.0.5.0I want to do
structural analysis for an si...
1 Reply
585
Views
by
hxia
on
Apr 17, 2023
06:54 AM
1178
Views
| Hello,I'm very happy to meet you here. I know you well,you can use Creo
simulate smoothly. Now I hav...
1178
Views
by
AvinashReddy
on
Nov 08, 2019
04:09 AM
Latest post on
Nov 13, 2019
03:06 PM
by
SweetPeasHub
4184
Views
| I wanted to Run multiple simulation at a time, i need a help how the
studies models will be set in o...
4184
Views
Using 6.0.1.0 and AFX and it has never worked. And the suggestions all
tell me that the two applicat...
624
Views
1 Reply
1573
Views
| I have designed a right-angled bracket to be made from 12 layers of
E-Glass. I have modelled it as a...
1 Reply
1573
Views
2123
Views
| I need to analysis the stick and boom models. I have tried to do the
boom but stress is high in boom...
2123
Views
by
Pranav_Ray
on
Jun 25, 2018
08:24 AM
820
Views
| I wish to know how to create new accessories for Manikins in Creo
Parametric 3.0 and how to assemble...
820
Views
by
ptc-676952
on
Sep 20, 2010
08:25 AM
Latest post on
Jun 24, 2018
05:23 PM
by
skunks
8713
Views
| Is there any benchmark for a elasto-platic material or even a
Hyperelstic material. It will be inter...
8713
Views
by
Pranav_Ray
on
Jun 21, 2018
04:25 PM
832
Views
| I wish to know about adding accessories and additional material to
manikins to change their appearan...
832
Views
1 Reply
1099
Views
| Hello dear ptc members,I am currently studying mechanical engineering
and had some troubles by simul...
1 Reply
1099
Views
by
VladimirN
on
Mar 02, 2018
03:55 AM
801
Views
| Please move this question in Creo area:
https://community.ptc.com/t5/Additional-Creo-Questions/bd-p/...
801
Views
by
346gnu
on
Oct 16, 2015
02:55 PM
Latest post on
Dec 08, 2017
08:20 AM
by
auijttewaal
4249
Views
| NOT SUPPORTED ! Was this the case before the fasteners became beams, I
haven't time to test? Ansys i...
4249
Views
by
fstopelli-2
on
May 09, 2017
05:51 AM
Latest post on
May 11, 2017
01:48 AM
by
fstopelli-2
1416
Views
| Hello! Sometime This happened to someone? It's no clear about the
problem of the 3D element.. Good L...
1416
Views
by
slee-10-11-12-1
1406
Views
| I've made a simple support structure on which about 150kg load is
applied and the structure is attac...
1406
Views
1593
Views
| Hello All, As Account for Stiffness option is available in Fastener
connection while applying Preloa...
1593
Views
by
cpreßinger
on
Mar 23, 2017
12:42 PM
Latest post on
Apr 05, 2017
03:32 AM
by
mlindqvist
1 Reply
1068
Views
| Hello, I am wondering if you can show the maximum stress for each
element caused by different loads ...
1 Reply
1068
Views
Are the beam elements created by the beam idealization in Simulate:
Euler or Timoshenko beam element...
1110
Views
by
sjanes
on
Mar 01, 2017
01:38 PM
Latest post on
Mar 23, 2017
03:05 AM
by
MartinHanak
1 Reply
1571
Views
| hello i have this message, someone can help me please Thanks a lot
1 Reply
1571
Views
1 Reply
771
Views
| How to find the weld shrinkage in plate 1 and plate 2 for weld rod moves
over the path?
1 Reply
771
Views
by
danderson
on
Nov 17, 2016
03:24 PM
Latest post on
Nov 18, 2016
12:20 AM
by
TomD.inPDX
1 Reply
1134
Views
| Really would have liked to see PTC buy this company. They have a very
nice basic CFD product that's ...
1 Reply
1134
Views
by
346gnu
on
Oct 17, 2016
05:58 PM
Latest post on
Nov 09, 2016
04:47 AM
by
pkloninger(cust
1245
Views
| Evening All, Has anyone come across this ... The model was originally
created in Creo2 M130 (custome...
1245
Views
by
ptc-5970743
on
May 16, 2014
04:12 PM
Latest post on
Sep 05, 2016
05:21 AM
by
cpatel-2
5726
Views
| Hello all, I am new to Pro Mechanica. I have a question regarding to
probe the reaction force and mo...
5726
Views
by
mmengarelli
on
Jun 10, 2016
09:11 AM
Latest post on
Jul 03, 2016
07:50 PM
by
DenisJaunin
1880
Views
| How can I change the unit of measure (from kPa to mPa) in the Linearized
stress report? thank you
1880
Views
by
rubenvillarreal
on
Jul 31, 2017
12:12 PM
Latest post on
May 29, 2016
11:47 PM
by
rubenvillarreal
1804
Views
| Hello, I would like to share my work. Check my blog for more
information. This was the result of a D...
1804
Views
2964
Views
| Creo3.0 M030 My surfaces are flat, holes are co-axial, only 2
components, the most benign model imag...
2964
Views
1837
Views
| Is there a way to change the text size in the results window for the
legend, type of stress with loa...
1837
Views
3795
Views
| Hello every one, I am designing a huge body for which as cast lifting
lugs to be provided. though mo...
3795
Views
1880
Views
| Hello, Is it possible to output the "resultant forces" on a few selected
surfaces from a large globa...
1880
Views
by
mlindqvist
on
Apr 07, 2015
09:24 AM
Latest post on
Apr 07, 2015
09:58 AM
by
unickque
1 Reply
872
Views
| I need to evaluate "stress range", i.e. max principal stress minus min
principal stress, for fatigue...
1 Reply
872
Views
