Analysis measurements showing as annotations
cjohnstone
3-Newcomer
Good morning -
I have a user who after doing an Analysis/Measure/Distance (or Length) is left with a 3D annotation that he can't erase, selector hide unless he closes the window and erases the file from his session. He's using my config, and I've never seen this, so I'm not sure what's going on - any ideas?
Thanks in advance -
Chrystal Johnstone
Red Dot Corporation
1 REPLY 1
I have a part that has a sketch on the top surface that is used for
engraving. The sketch clutters the drawing of the part too much so I
wanted to create a separate view for just the engraving. I've created a
simp. Rep. with the sketch excluded but I already have dimensioned views
on my drawing.
Is there any easy way to change an existing view to the simplified rep
view? The new views come up correctly once I set the model.
T
