Another Creo issue
  • May 9, 2013
  • 0 replies
  • 498 views
Just testing out the transition from M030 to M050.
The location of the PTC folder inside the APPDATA folder changes with each release. But between M030 & M050, not only did the version change, it changed from Roaming to Local, and an extra folder level was inserted.
%USERPROFILE%\AppData\Roaming\PTC\Creo\Platform\2.11\ServerMgr\.srv_mgr_db.fldx <--M030
%USERPROFILE%\AppData\Local\PTC\Creo\Platform\2.19\agent\ServerMgr\.srv_mgr_db.fldx <-- M050
This is important if you want to have a startup without PDMLink. You need to delete this file in your startup script.
Like this:
del "%USERPROFILE%\AppData\Local\PTC\Creo\Platform\2.19\agent\ServerMgr\.srv_mgr_db.fldx"
del "%USERPROFILE%\pro\creo_2_home\no_pdm_cache\PTC\ProENGINEER\.wfwsi2008
del "%USERPROFILE%\pro\creo_2_home\no_pdm_cache\PTC\ProENGINEER\.Settings\active_server_config.fld
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
