Automatically go to sketch view and open reference window after selecting "command" and selecting sketch plane
ptc-4168940
7-Bedrock
Hi all,
If I remember correctly, in WF5, any time you selected a command, such as extrude, revolve, etc., and selected your sketching plane, the references and/or sketch setup dialogue window would open (I can't remember which, if not both). After verifying or selecting the desired refernces, it would then atomatically go to the sketch view. What options in my config file do I need to add so that when I choose extrude or revolve and select my sketch plane, the sketch setup window opens, then the references window opens, and then lastly, it auto-rotates to the sketch view? I have setup mapkeys for some of these (such as "sv" for sketch view), but would like to streamline it a little bit more.
Sam
6 REPLIES 6
Dale_Rosema
(To:ptc-4168940)
This is from WF5
This is for the 3rd request - automatically orienting the sketch to the sketch plane.
sketcher_starts_in_2d
Defines initial model orientation in Sketcher mode. Yes -
(2D orientation) Looking directly at section (sketching)
plane. No - (Orientation unchanged) Sketch directly on
the 3D part.
I hope this is what you are looking for.
Dale
Dale_Rosema
(To:ptc-4168940)
Could this be another?
feature_create_auto_begin
In feature creation, determines whether or not the
Define button is automatically activated when you open
the dialog box. Yes - Button is activated automatically.
No - You select the button
Thanks, Dale
Dale_Rosema
(To:ptc-4168940)
Possibly the other?
feature_create_auto_ok
system activates the dialog box OK button automatically
when the last required element is defined. Yes – Button
is activated automatically. No - You select the button.
Thanks, Dale
I had the same issue. Use "sketcher_starts_in_2d yes" and it will do just that.
Well Dale, I've hd those both set to yes for a long time now, and it still requies you to pick whether you want to define an internal sketch or use an existing sketch. I WISH it automatically went to a sketch, but.....
Frank,
I got those out of the 128 pg pdf that you linked to on a Jun 14 post. I was searching to see if I could find things that would be relevant.
Dale
