Auxiliary Applications issue
ktool
I am using Creo Parametric Release 7.0 and Datecode7.0.2.0
Auxiliary Applications toolkit file running but not able to see it under tool kit
There is no error or warning message, the toolkit is running properly in Auxiliary applications window, problem is that tool kit not show up in Creo7.0. it works well with same setting before, now the toolkit icon disappear even it shows running after registered. wondering anything block the path or other issues.
Michael
(To:ktool)
To address the issue you're experiencing with the Auxiliary Applications toolkit not showing up in Creo Parametric Release 7.0.2.0, even though it appears to be running properly, here are a few steps and considerations that could help resolve this issue:
1. **Configuration File Check**: Ensure that the configuration files (`config.pro` or `config.sup`) are correctly set up for the toolkit. Missing or incorrect settings in these files can prevent the toolkit from appearing in Creo.
2. **Compatibility and Updates**: Verify that the toolkit is compatible with Creo Parametric Release 7.0.2.0. If it was working with previous versions, there might be compatibility issues with the new release. Check for any updates or patches for the toolkit that might be required for the newer version of Creo.
3. **Path Settings**: Double-check the path settings in Creo to ensure that they correctly point to the location of the toolkit files. Incorrect paths can lead to Creo not being able to locate the toolkit.
4. **License and Permissions**: Ensure that the toolkit is properly licensed and that you have the necessary permissions to use it. Sometimes, toolkits may fail to display due to licensing issues or restricted user permissions.
5. **Reinstallation or Repair**: If the above steps don't resolve the issue, try reinstalling or repairing the toolkit installation. This can resolve any corrupted files or settings that might be causing the issue.
6. **Consult Documentation or Support**: Refer to the toolkit's documentation for specific installation instructions or known issues. If the problem persists, consider reaching out to the support team for the toolkit or PTC support for assistance.
7. **Check for Conflicting Software**: Ensure that there is no conflicting software or plugins that might be causing the toolkit to not display correctly. Sometimes, other installed software can interfere with the proper functioning of toolkits in Creo.
8. **System Requirements**: Verify that your system meets the necessary requirements for both Creo Parametric 7.0.2.0 and the toolkit. Incompatibility with system hardware or software can cause issues.
If the problem continues after trying these steps, it may require a more in-depth investigation specific to the toolkit you are using and its integration with Creo Parametric.
~ CreoVerse
ktool
(To:Michael)
Thanks for reply, we tried all these kind of solution from list provide by Chatgpt, still not working as our expecting, the other two works fine and last tool kit is not appear at all.
