Auxiliary Applications issue
I am using Creo Parametric Release 7.0 and Datecode7.0.2.0
Auxiliary Applications toolkit file running but not able to see it under tool kit
There is no error or warning message, the toolkit is running properly in Auxiliary applications window, problem is that tool kit not show up in Creo7.0. it works well with same setting before, now the toolkit icon disappear even it shows running after registered. wondering anything block the path or other issues.
