CREO 2.0 PARAMETRIC model mouse wheel rotate not working
  • January 29, 2016
  • 4 replies
  • 8602 views
Hi Guys,
I have installed CREO 2.0 in my machine and opened the model files.
When i opened the model i can able to zoom in/out the model using mouse scroll button but cant able to rotate the model. Is there any settings i need to apply for model rotate?
Your little help is much appreciated since i am struck up in the earlier stage.
OS : Windows 10/ WIndows 7
Mouse : 3 Pointer mouse(left, right, middle scroll button)- DELL
You have somekind of additional mousesettings driver installed ?
For example : with a logitech-mouse you can install the Setpoint software.
There you can choose the function for the middle mouse button. Rotating in Creo will only work when the setting is "middle button".
You can't choose this in the normal windows driver (but then it normally works...).
Also, only Creo 2 M190 and later are certified for use with Windows 10.
Thanks all for your kind reply. The culprit is DELL mouse. When i changed my mouse the rotate working well.
Dale_Rosema
Don't forget to mark your answer as correct.
