my suggestion... ask the person who created the standard configuration in Creo 9.0.
There are a couple of files that relate to this that you will need to copy from your Creo 9 structure to your Creo 12 structure.
The first files to copy over are the config.sup and the config.pro files from the common files/text folder. These may be in another folder if you use some environment variables for the alternate location.
The second set of files to copy is your start model templates, unless these are on a shared network drive that the config.pro has their location defined.
Hello @SD_10196069,
It looks like you have some responses from some community experts. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
