Creo 2.0 trial license
Susan
I downloaded Creo 2.0 30 day trial and have installed it. I received a sw_license_email_(numble).dat. Where should I save it to?
TomD.inPDX
(To:Susan)
Wherever you want. It will ask for it during the install process. At that time you can drag-n-drop the license file when requested.
Thanks. But I follow the trial installation instruction
  • Open up Windows Explorer and navigate to C:\ProgramData\PTC\Licensing.
  • Locate and delete the current trial license file – BC390204EDCREO2TRIALCD_license.dat
  • Select the file, right mouse button on it and select delete.
  • Run the trial install procedure again.
no licernse file is requested. ??
TomD.inPDX
(To:Susan)
Interseting... did you have a previous version installed? Did you uninstall the previous license manager? Does the new version run or are you stuck in the install somewhere?
