Creo 3.0 Performance
ErikZabokrtsky
Is it just me or does Creo 3.0 take longer to Check In/Out and Upload than Creo 2.0 did? We went from Creo 2.0 M090 to Creo 3.0 M090, and it definitely works harder to communicate with Windchill. Our Windchill server is currently on 10.0 M030, we are already looking at upgrading it, but are there any config changes that need made between 2.0 and 3.0 that I possibly missed?
It's a company wide, multiple location, speed issue that definitely came about after upgrading to 3.0. Just looking for ideas that maybe I don't know about until we can get Windchill up to date.
Erik
4 REPLIES 4
TomU
(To:ErikZabokrtsky)
Have you compared file sizes?  There were some changes made to shade quality that can cause much larger files to be created if the setting is cranked up.
I just went back compared 15-20 of them and they are either close to the same size or even smaller. One assembly that the engineer's have been working with is 348KB and it takes just shy of a minute and a half to check it in now. It was 339KB when we had Creo 2 and never took any where near that, don't have exact time to compare to but know they didn't wait that long.
TomU
(To:ErikZabokrtsky)
Good to know.  Do you have the PTC System Monitor installed?  I wonder if maybe you could use Fiddler or Wireshark and compare the traffic during a check in from each version...
according to http://support.ptc.com/WCMS/files/124498/en/PTCWindchillCreoSWCompatibility10x_92515.pdf Creo 3.0 is not compatible with WCH 10.0
MH
Martin Hanák
