Creo 6.0.6 cannot start after a new installation
jli-5
3-Newcomer
I am using Creo Parametric Release 6.0 and Datecode6.0.6.0
after new installation, it cannot start
cannot start, and no xtop and no logs
Tried to follow the guide of https://www.ptc.com/en/support/article/CS258965, but still the same thing
BTW, the user also has Creo 4.0 installed on the same PC. Should he remove Creo 4.0 first or?
MartinHanak
(To:jli-5)
it is not necessary to remove Creo 4.0.
Try adding following option into config.pro file and start Creo 6.0
graphics win32_gdi
Martin Hanák
remy
(To:jli-5)
How is Creo started?
Do you run a start script ? Is the desktop shortcut being used?
All in all, did you try firing the parametric.exe directly from <Creo Load Point>\Parametric\bin?
