Creo 6.0.6 cannot start after a new installation
  • May 31, 2022
  • 2 replies
  • 826 views
I am using Creo Parametric Release 6.0 and Datecode6.0.6.0
after new installation, it cannot start
cannot start, and no xtop and no logs
Tried to follow the guide of https://www.ptc.com/en/support/article/CS258965, but still the same thing
BTW, the user also has Creo 4.0 installed on the same PC. Should he remove Creo 4.0 first or?
    it is not necessary to remove Creo 4.0.
    Try adding following option into config.pro file and start Creo 6.0
    graphics win32_gdi
    How is Creo started?
    Do you run a start script ? Is the desktop shortcut being used?
    All in all, did you try firing the parametric.exe directly from <Creo Load Point>\Parametric\bin?
